  New Posts New Posts RSS Feed - throat sizes for V18-1000 - hornresp
collision View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote collision Quote  Post ReplyReply Direct Link To This Post Topic: throat sizes for V18-1000 - hornresp
    Posted: 15 February 2012 at 4:23pm
hello guys,
i have been working out a rough plan for a rear loaded horn for the void 1000,
used the equations found here to aid me. http://fullrangedriver.com/singledriver/horndesign.html
using those equations i ended up with 2.73cm2 which really does not seem right....(although i dont actually know)
been using hornresp and have hit some issues. my impedance and frequency plots are all over the place are there any pointers that anyone can suggest that might be a major factor? compression ratio? length of horn? flare rate?
Thanks
Tom
ONE LIFE. AVE IT.
doober View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doober Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2012 at 8:11pm
Are you certain you did the conversion of VAS into cubic metres, and the conversion of At into cm2 correctly? There are 1000 litres in a cubic metre, 10000 cm2 in a m2. Ive made mistakes with these way too many times....
Blahblahblah
JR.junior View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JR.junior Quote  Post ReplyReply Direct Link To This Post Posted: 15 February 2012 at 9:54pm
You don't need to make conversions. You just put the values in the equation as they are and the result you get are cm2. You should get 27,3cm2
Edited by JR.junior - 15 February 2012 at 10:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote doober Quote  Post ReplyReply Direct Link To This Post Posted: 16 February 2012 at 7:58pm
I make it 273cm2, it is necessary to use the correct units in the formula or the result ends up one decimal place out.
273cm2 is probably still too small a throat area for an 18" driver though. What frequency range were you looking for Tom? You may find that a suitable flare rate makes the horn ridiculously long with such a small throat.
Kieran
Blahblahblah
Forum Software by Web Wiz Forums® version 10.11
