TMS-2 upgrade & Simulation |
tv00
Topic: TMS-2 upgrade & SimulationPosted: 29 March 2012 at 1:20pm |
Hi everybody, I've tried to model the tms-2 horn, based on daves model for the hd15
I have one big question about hornresp: Where do I enter driver sensitivity? the rcf mb15n401 has 100db sensitivity & the lf15n401 has 97, but they model the SAME in hornresp. Appart from different sensitivity the also have different BL & so on. I will upload my input screen with plots here soon, just that they're on a different pc now. My plan is to load the tms-2 with mb15n401 MR10N301 10" with phaseplug bms 4538 / 4540 extended range 1" (to 30khz they say) Regarding the 10" I don't know if the phaseplug is really long enough to fit in the horn part. First i have to listen, I think of moulding a copy of the outer part of the tms-2 plug onto the rcf plug to make it fit in the horn |
SvempaPrim
Joined: 24 February 2011 Location: Sweden Status: Offline Points: 50 |
Posted: 03 April 2012 at 10:06pm |
Regarding the 10" horn, do you still have the horn w phaseplug? Or what is the reason loading it with rcf?
tv00
Posted: 03 April 2012 at 10:11pm |
Yes i have, the plug is a copy, the reason was to try / learn something & to play louder :-)
SvempaPrim
Posted: 03 April 2012 at 10:29pm |
Ah cool :) learning is always a good reason. Just a tip tough, the guy who desgined the THAM has also modified the phaseplug in the torbomid to fit a modern (b & c 12pe32 Iirc) driver. Could be worth checking out if the plug you have is a decent copy!
Www.martinsson.cc |
SvempaPrim
Posted: 03 April 2012 at 10:30pm |
Alot cheaper that buying those rcfs with plugs...
tv00
Posted: 03 April 2012 at 10:54pm |
Thanks for the suggestion.
What would i want to stick that in there for? Guess I would lose quite a bit high freq responce!? It's no problem for me to do a perfect (better than turbosound) copy of the phaseplug. But that itself is useless! I get the rcf's cheaper than we do here in northern europe, italy & france has cheap prices:-) My point is that the phaseplug has to fit the cone: the rcf plug fits the rcf cone. the tms plug fits the horn. Still you're helping me, because if he has no problems with a 12" in there then I think I will have no problems woth the altered loading area in the rcf-plug. Probably I just have to mould the front of the tms-plug onto the rcf-plug, but testing & calculating is needed. I better ask Martinsson like you suggest. |
SvempaPrim
Posted: 03 April 2012 at 11:21pm |
oh sorry, i wrote the wrong driver. stupid me. Off course he modified the plug to fit a 10" driver in the original horn, and still gettin up to 3.7 khz. I mailed him and ask how he did it but got a pretty fuzzy result about just shaping the back of the plug exactly as the dustcap. He has put up an measurement on his website wich actually looks really good. Have a 6 tms-2s in pretty awful condition, i am thinking of doing this myself and build new trap cabs.
I know the man himself is a regular here on the forums, maybe he can shed som light on this? :)
Edited by SvempaPrim - 03 April 2012 at 11:34pm |
Tweet
