  New Posts New Posts RSS Feed - TMS-2 upgrade & Simulation
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Topic: TMS-2 upgrade & Simulation
    Posted: 29 March 2012 at 1:20pm
Hi everybody, I've tried to model the tms-2 horn, based on daves model for the hd15
I have one big question about hornresp:
Where do I enter driver sensitivity?
the rcf mb15n401 has 100db sensitivity & the lf15n401 has 97, but they model the SAME in hornresp.
Appart from different sensitivity the also have different BL & so on.
I will upload my input screen with plots here soon, just that they're on a different pc now.
My plan is to load the tms-2 with
mb15n401
MR10N301 10" with phaseplug
bms 4538 / 4540 extended range 1" (to 30khz they say)
Regarding the 10" I don't know if the phaseplug is really long enough to fit in the horn part. First i have to listen, I think of moulding a copy of the outer part of the tms-2 plug onto the rcf plug to make it fit in the horn
SvempaPrim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SvempaPrim Quote  Post ReplyReply Direct Link To This Post Posted: 03 April 2012 at 10:06pm
Regarding the 10" horn, do you still have the horn w phaseplug? Or what is the reason loading it with rcf?
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 03 April 2012 at 10:11pm
Yes i have, the plug is a copy, the reason was to try / learn something & to play louder :-)
Post Options Post Options   Thanks (0) Thanks(0)   Quote SvempaPrim Quote  Post ReplyReply Direct Link To This Post Posted: 03 April 2012 at 10:29pm
Ah cool :) learning is always a good reason. Just a tip tough, the guy who desgined the THAM has also modified the phaseplug in the torbomid to fit a modern (b & c 12pe32 Iirc) driver. Could be worth checking out if the plug you have is a decent copy!
Www.martinsson.cc
Post Options Post Options   Thanks (0) Thanks(0)   Quote SvempaPrim Quote  Post ReplyReply Direct Link To This Post Posted: 03 April 2012 at 10:30pm
Alot cheaper that buying those rcfs with plugs...
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 03 April 2012 at 10:54pm
Thanks for the suggestion.
What would i want to stick that in there for?
Guess I would lose quite a bit high freq responce!?
It's no problem for me to do a perfect (better than turbosound) copy of the phaseplug.
But that itself is useless!
I get the rcf's cheaper than we do here in northern europe, italy & france has cheap prices:-)
My point is that the phaseplug has to fit the cone:
the rcf plug fits the rcf cone.
the tms plug fits the horn.
Still you're helping me, because if he has no problems with a 12" in there then I think I will have no problems woth the altered loading area in the rcf-plug.
Probably I just have to mould the front of the tms-plug onto the rcf-plug, but testing & calculating is needed.
I better ask Martinsson like you suggest.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SvempaPrim Quote  Post ReplyReply Direct Link To This Post Posted: 03 April 2012 at 11:21pm
oh sorry, i wrote the wrong driver. stupid me. Off course he modified the plug to fit a 10" driver in the original horn, and still gettin up to 3.7 khz. I mailed him and ask how he did it but got a pretty fuzzy result about just shaping the back of the plug exactly as the dustcap. He has put up an measurement on his website wich actually looks really good. Have a 6 tms-2s in pretty awful condition, i am thinking of doing this myself and build new trap cabs.
I know the man himself is a regular here on the forums, maybe he can shed som light on this? :)
Edited by SvempaPrim - 03 April 2012 at 11:34pm
speakerplans@redhotmail.net
