  New Posts New Posts RSS Feed - To good to be true?
To good to be true?
Crazy Dane View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crazy Dane Quote  Post ReplyReply Direct Link To This Post Topic: To good to be true?
    Posted: 06 December 2011 at 4:43pm
I just came across this plan: http://boyzpc.home.xs4all.nl/Bouwtekeningen/Overig/CW218%20sub.pdf
107,5dB sensitivity..!
Is it just me or does that sound a little bit like whish thinking?
You can never use to much glue!!
burningbush View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote burningbush Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2011 at 5:05pm
It says -3dB at crossover, even still seems a little high.  At what frequency is the sensitivity measured though?
Hud 'at ye bam
Post Options Post Options   Thanks (0) Thanks(0)   Quote Crazy Dane Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2011 at 5:26pm
That is my thought too..
They dont say where it is that sensitive.
My Cubo215 has a sensitivity of 107dB at 120hz, but i do cut them off at 112hz. So that doesnt meen anything to me :)
Saturnus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Saturnus Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2011 at 6:02pm
 Given the dimensions I'd estimate that sensitivity to be at 150Hz or higher. It's also evident that the sensitivity boost does not come from the V shape which will not give any boost at the rated frequency range but from misaligning the two cabs with different Q values. Don't try this at home kids. It will sound horrible.
Edited by Saturnus - 06 December 2011 at 6:07pm
kevinmcdonough View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevinmcdonough Quote  Post ReplyReply Direct Link To This Post Posted: 06 December 2011 at 11:28pm
yep,  far too good to be true.
To me, this isn't a horn but essentially just a reflex with the drivers mounted backwards so they face into their ported chambers?  You may get a db or two from the v loading of the two drivers but certainly nothing that will be even close to 107db  in their pass range, its no where near the length of any sort of proper horn.
k
salzburgsoundsystem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote salzburgsoundsystem Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2011 at 6:25pm
Maybe running 2.83 Volts into a parallel pair of four Ohm drivers... at 1 kHz?
Noize-Guerilla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Noize-Guerilla Quote  Post ReplyReply Direct Link To This Post Posted: 21 December 2011 at 12:24pm
Looks like the KS CW218 ,
http://www.djlukas-meyer.de.tl/KS-CW218.htm
http://www.google.com/imgres?q=pozor+smeti&um=1&hl=de&client=safari&sa=N&rls=en&biw=1024&bih=873&tbm=isch&tbnid=jwkckFybVryYvM:&imgrefurl=http://www.tekknoost.de/forum/viewtopic.php%3Fp%3D31259&docid=fx5u3lLRCTFLIM&imgurl=http://lh5.ggpht.com/_I43ffsInwa8/Snag8aYBP8I/AAAAAAAABU8/u7RP3L_49tM/P8026857.jpg&w=1346&h=786&ei=r9DxTqGHNcjMtAbX1JUU&zoom=1&iact=rc&dur=412&sig=114229871638482036966&page=1&tbnh=123&tbnw=211&start=0&ndsp=16&ved=1t:429,r:0,s:0&tx=109&ty=23
Here, in Action:
http://www.youtube.com/watch?v=3bmy2rv_ZpU&feature=related
Greetings
Edited by Noize-Guerilla - 21 December 2011 at 12:34pm
I'm not poor, but money doesn't make me rich.
Forum Software by Web Wiz Forums® version 10.11
