Tom Danley and Yorkville offer more... |
Page <1234 5> |
turbodeas
Joined: 06 August 2005 Location: United Kingdom Status: Offline Points: 272 |
Posted: 23 August 2008 at 12:35am |
Interesting stuff.
Possibly a bit of a basic question, but the two "holes" across each 10 inch driver - are they there to act as an acoustic low pass filter? I've noticed quite a few line array boxes have their mid drivers partially covered up by some solid material and was wondering why this is, as opposed to just a standard metal grille....I did wonder whether it was to move the point of radiation closer to the HF in order to give more coherancy when the wavefronts combine? Cheers, Chris. |
Steve_B
Joined: 29 September 2007 Status: Offline Points: 851 |
Posted: 22 August 2008 at 1:51pm |
Without delving in to the theory too deeply, the dispersion angle of a straight sided horn is set by the angle between the two walls. With a given mouth and throat size, set by drive unit choice and operating frequency range, the only way to reduce the angle between the horn walls, and hence dispersion angle, is to make the horn longer. The idea of the various high frequency devices used in line arrays is to create a shallow device that behaves as though it was a long horn.
If you don't mind a very deep cabinet, the long horn method should work |
AshayinFLA
Joined: 22 August 2008 Location: South Florida Status: Offline Points: 3 |
Posted: 22 August 2008 at 9:22am |
A company I work with has 12 of these cabinets, and 8 of the double-12" subs.
So far, I have not heard them out in the field, but we did listen to a few of them in the shop. They definitely need some eq (apart from the processor settings initially on them). For the most part they come WAYYY too bright. Cutting between 4-8db (depending on taste, etc) from 6.8k> smoothes them right out. They are also slightly harsh in the mids, but a couple of db down at 600-800hz fixes them right up! Apart from that, these are GREAT SOUNDING boxes! They do throw VERY FAR (we walked out of the warehouse and a good 50-75 feet with lots of pressure of in-your-face clean sound!) Theres a few downgrades to using them in the field (at this time you cannot groundstack and point the bottom cabinets at a downward angle, without "figuring out" how to), and the finish is kinda "cheesy" and looks like it will easily scuff or even break! The double-12" subs are SIMPLY AMAZING (well, for 12" subs anyway). The amount of pressure that comes out of these cabinets is nuts! Groundstacked subs made a huge difference over flying 2 subs with the fullrange cabs underneath. My boss is a distributor for these boxes, and although I don't know the numbers, they are supposedly really cheap, in comparison to other similar cabinets! They are priced low because of some of the "weaknesses" like the painted wood, and a few other very little complaints. These boxes are currently in Boca Raton, FL if anybody wants to demo them. Saturday we will be using 1 sub and 2 tops per side as sidefills for kc and the sunshine band. If anybody is interesting I can let you know how their engineer likes them. ps Their processor (4-in, 8-out) is SIMPLY AMAZING for the price! Each output has 8 parametrics + low/high pass filters on each output, as well as up 50 650ms delay (in .01ms steps), full limiter, phase, and a matrix mixer to send any input to each output at whatever level you want. Each INPUT has phase, gain, delay, 8 parametrix, lp/hp, compressor, AND a 31 band graphic EQ (you can use all the eq's at once, not just parametric or just graphic)!!! Every port (input, output) can be named. Theres 30 presets to store your settings! The system has usb, serial, AND ethernet connections to the computer program, but ALL functions can be accessed from the front panel! Also, it is 1 rack space! VTC gets these from another manufacturer (whose name I forget) but they sell CHEAP (well under $1000 for all this!) I think the manufacturer has other units, with up to 8 in, 16 out if I remember right!!!! Edited by AshayinFLA - 22 August 2008 at 9:26am |
_djk_
Joined: 23 November 2004 Location: United States Status: Offline Points: 3516 |
Posted: 07 February 2008 at 8:23am |
From someone that has actually heard them:Got to hear some brand spanking new speakers last week...
Edited by _djk_ - 07 February 2008 at 8:25am |
djk
bassmish
Joined: 28 October 2007 Location: MAAAANCHESTER Status: Offline Points: 1190 |
Posted: 29 January 2008 at 9:37pm |
I'm doing an experiment on fresnel diffraction at a slit next week for my course, sounds relevant, best have a look at that!
Calitri
Joined: 02 November 2004 Location: Finland Status: Offline Points: 132 |
Posted: 29 January 2008 at 10:39am |
Just yesterday had an idea about the "deeper horn" part, could it refer to the fact where in normal line array horns the waves from the center of the horn would have to pass the same distance as the sides to create a vertical plane of sound, which is usually done by bending the center path. So perhaps the horn's throat refers to that difference. So instead of say 20 cm long line array horn you can have 2-4 cm long "horn" that creates the same kind of vertical plane, which in my mind brings the question that could it be just a simple Fresnel lens type thingy? It does exactly that type of result but with light so it just might be the same idea adapted to sound...
bassmish
Posted: 28 January 2008 at 1:07pm |
thats not what I'm on about , just gaining the same performance of a conventional throat horn from a smaller design is not all that this thing does apparently. I was refering to a similar effect of the spreading out/diffraction displayed by light as it passes through a slit, or water through a hose pipe when you squeeze the end.
And, a conventional throat horn would not have a variable path length, or would it, what is the meaning of a continuously variable path length? |
_djk_
Posted: 27 January 2008 at 11:32pm |
"the c'haracteristics of a deeper horn' are just refering to the way sound becomes more "
No, it means the the length of the horn using the same driver would have to be much longer with a conventional throat construction.
djk
bassmish
Posted: 27 January 2008 at 7:47pm |
maybe, the c'haracteristics of a deeper horn' are just refering to the way sound becomes more omni directional as the frequency decreases, but using this slit and a lot of pressure created by the dimensions of the waveguide, the sound will perform as a 'deeper horn' and spread out a large amount more? Sounds quite wrong.
I guess that a non variable path length would just be like a straight tube, so maybe adding a few 90 degree corners creates lots of disturbance in the path taken by the wave and consequently creates a continuously varying path length. maybe this unstability in the path taken by the wave causes a higher pressure inside the wave guide, hence they said, 'such that the high frequency......' |
boab
Joined: 21 June 2004 Location: Busby Status: Offline Points: 353 |
Posted: 26 January 2008 at 12:22pm |
I think that the key may be in the statement...
"The Paraline element is a horn configuration that provides an effective impedance transformation while at the same time providing a way to adjust the path length in a continuously variable way, such that the high frequency dispersion pattern produced has the same characteristics as that of a much deeper horn." http://vtcproaudio.com/ |
H..
Joined: 07 August 2007 Location: Thailand Status: Offline Points: 197 |
Posted: 26 January 2008 at 9:20am |
Slot tweeter on a horn then!
bassmish
Posted: 24 January 2008 at 11:20pm |
Hello,
I'm not entirely sure what the problem that was intended to be solved by this design was, which makes this a bit pointless, and I'm also not sure if this is what steve B was saying. But. I think what's happening from looking at the picture is that the sound is no longer sent through a horn to present an acoustic impedance, but rather sent around a symmetrical (about the horiziontal) object/waveguide. This waveguide will have dimensions so as to suite the frequencies being transmitted as steve said (smaller than the wavelength?), e.g to eliminate standing waves, not to decrease HF response. The sound passes around the symmetrical object, then is presented with a large acoustic impedance in the form of a 1'' slit/hole. It is forced out of this slit and spreads out, at which point the horns take over combining the two sources in a clever way. Is this what you were saying/obvious? Bassmish |
Page <1234 5> |
Tweet
