  New Posts New Posts RSS Feed - Top for miniscoop mk2
Nikaaa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nikaaa Quote  Post ReplyReply Direct Link To This Post Topic: Top for miniscoop mk2
    Posted: 08 January 2011 at 10:42am
Hello,
I'm beginner and can you give me an advice/share your experience which Top should I set up for miniscoop.
Also, top should work on 70-80 Hz (would be pleasant for (2 X 12 + 1) type).
Components I have are RCF MB12G301.  PDF
Any response and idea is important for me.
Thanks beforehand.
approximately as
Nitz V1505 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nitz V1505 Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2011 at 12:40pm
You might struggle to get the 12's down to 70-80hz. However the right mini scoop can play to 100-110hz. You might wanna consider 15's so you get some kick or run 3 way with dedicated kicks below the 12's.
