Tapped Horn By Startec |
Post Reply | Page 12> |
dj-panoramix
Registered User Joined: 28 September 2005 Location: France Status: Offline Points: 462 |
Posted: 23 October 2008 at 9:40pm |
hi !!
her it's:
the simulation is made with a rcf18LX
rcf G4o1 et le N4o1 can be use. Edited by dj-panoramix - 23 October 2008 at 9:50pm |
jahseriah
Registered User Joined: 19 July 2007 Location: United States Status: Offline Points: 65 |
not bad
Deadbeat
Old Croc Joined: 12 March 2008 Location: Singularity Status: Offline Points: 3167 |
I'm interested in some measurements - I predict much more flatness and less efficiency than the sim.
This Mr Startec is quite the celebrity on those French forums. |
Away on extended leave.
MarjanM
Old Croc Joined: 10 February 2005 Location: Macedonia Status: Offline Points: 7810 |
This reminded me of Mircea's drawing from two years ago.
djstefanos
Old Croc Joined: 18 November 2005 Status: Offline Points: 2355 |
Deadbeat
Why the gasp? There's only so many ways you can fold a tapped horn - it is the individual design that counts.
wafflesomd
Young Croc Joined: 21 September 2007 Status: Offline Points: 811 |
Interesting.
I might try out 4 of these next year. Efficiency looks kinda meh, but with high power its sure to be loud. Do tapped horns gain anything from coupling? |
heinrich
Registered User Joined: 21 February 2007 Location: Calindagan Status: Offline Points: 280 |
well the thing looks good..........
I just don't understand why the HOG was not also called a tapped horn............ aaaaaaaaaaaahhhhhhhhhhhhhhhhh yes!!!!! I understand then.........because the drivers were not reversed in the HOGs.......... Edited by heinrich - 24 October 2008 at 6:55am |
.....power is nothing without control....
adambomb
Old Croc Joined: 10 April 2006 Location: United Kingdom Status: Offline Points: 3220 |
scoops are similer in some ways to TH..
It's not the driver being the other way round that's the difference tho... The main difference is where the driver is in the horn path. |
el_dj
Registered User Joined: 30 November 2007 Location: Denmark Status: Offline Points: 176 |
perhaps stupid question... sorry :)
but do you reversed polarity on the driver in this cabinet!
Old twat, with an interest in light & sound
FlipC
Young Croc Joined: 25 October 2007 Status: Offline Points: 654 |
Having built 3 TH's you do not reverse the polarity.
Deadbeat
It's actually the principle used that is the main difference. Tapped horns work on mouth reflections which lets the cab create so many resonances it ends up ruler flat. If you folded out the Hog, you could call it a tapped horn. But when the driver is in that position on the Hog, I'd start doubting whether reflection occurs. Adam is right, some do have the driver further back. Heinrich, the magnet doesn't have to face out.
