-=SHOW OFF YOUR SOUND SYSTEM!!!!=- |
Post Reply | Page <1 379380381382383 735> |
Author | ||||
tallmike
Old Croc Joined: 18 September 2007 Status: Offline Points: 2684 |
Posted: 02 February 2009 at 11:34pm | |||
No no no.. the Quakes and CQ's were supplied by us!
mykey
Old Croc Joined: 18 August 2005 Location: UK/Indonesia Status: Offline Points: 9680 |
Posted: 03 February 2009 at 2:55am | |||
what do you make of this mike?
My Demo1 I designed after reading all the GOOD reviews on the EM site, obviously they won't have any bad ones but read this from CSG
"Hello Mikey The em quakes seem to be very depenant on position / performance. in their first position against a wall and on the floor, they sounded like a bag of nails. when we moved them to the position in the pic, they were much happier. they drop lower than the punnishers, but the puns make a far better 1 box bass solutuon with greater output, punch and speed. for my purposes, i dont need to go below 40. as far as most people are concerned, 40 is really low, and far lower than most pa systems reach effectively" Now, the Puns don't come anywhere near the Demo1 Don't believe the Hype as they say? or are they tastey? it all reads very tastey on their site
H...
Young Croc Joined: 21 July 2008 Location: UK Status: Offline Points: 1164 |
Posted: 03 February 2009 at 7:40am | |||
Quakes need to be in blocks of 4 stacked 2 wide 2 high so the 4 mouths make one big mouth to really get the most out of them, if you have more just go higher.
I've never heard a 'single quake' but i would guess it would have the same problems a most horns when not stacked together - ie not much LF.
Maybe tallmike can comment as i believe he has a few - i've only ever heard 4 stacked as above and it was pretty stonking IMHO.
csg
Old Croc Joined: 17 September 2007 Location: bedford Status: Offline Points: 6086 |
Posted: 03 February 2009 at 8:55am | |||
well, interestingly ( and since my posts seem to be jumping between threads!), in their first "unhappy" position, they were stacked just like that - ie 2 high, 2 wide, with the further advantage of quarter space loading from the large rear brick wall, and concrete floor. they did not work well at all in that position - so badly infact that Mike and I were looking at each other, wondering if some drivers were blown / out of phase etc
we even tried different amps - swapping the FFA for a PL380 etc, but no good
on moving the bins to 4 in a line in 1/2 space, with the mouths nearest the floor, they really opened up and i would say that they performed very well indeed - the trade off for the extra extention compared with the punnishers being slightly lower spl capability as you would expect
all in all, whilst the quakes are not the holy grail of subs, they seem to be very effective indeed if used / stacked in a way they like - and at sub 40Hz, results seem to be ever more depenant on the enviroment, as well as the enclosures producing those frequencies
H...
Posted: 03 February 2009 at 9:24am | |||
Mmm I heard them at the pub round the corner from Plasa - seemed to work in there.
tallmike
Posted: 03 February 2009 at 9:35am | |||
For a lot of uses, the Quakes aren't the best solution - they do go very low, but like most people I don't need to go below 40hz either, so for almost all smaller jobs I use 215s. I think the way that the Quake performs very well is in terms of linear response (as far as I know, it was never designed to be a 'dance' sub, just as a large-format LF extension for a sound reinforcement system), and the ability to throw very far... to be honest we never really did much listening from afar, just judged the bins on what they sounded like from 10 feet away. Which to be honest, shorter horn bins with more drivers would be more effective at. I was very impresed with Chris's punnishers, they really sounded good, and just as importantly they are designed as such that you can get an awful lot of sound into a van and still have room!
Wrighty
Old Croc Joined: 17 April 2004 Location: Devon Status: Offline Points: 1801 |
Posted: 03 February 2009 at 10:03am | |||
It was snowing hard in Tavistock this morning and there's been a bit more at work (middle of the moors) over night... http://www.dartcom.co.uk/dartcam |
mykey
Posted: 03 February 2009 at 10:58am | |||
sorry Mike & chris, didn't realise you were at the same gig
Contour
Young Croc Joined: 03 March 2004 Status: Offline Points: 623 |
Posted: 03 February 2009 at 9:30pm | |||
It seems csg/Chris has done a very good job on his double Punisher bins. A mistake many people seem to make is to build a single Punisher and judge the design from that. Using a block of four or more is a much more appropriate way of showing the capabilities of the design. And of course a rock solid build also helps!
Best regards,
Walt
the smf
Registered User Joined: 08 May 2008 Location: United Kingdom Status: Offline Points: 761 |
Posted: 04 February 2009 at 5:47pm | |||
and now...........
Existenze Records - http://www.chemical-records.co.uk/sc/downloadstore/release/6625
RosscoPico
Young Croc Joined: 31 January 2007 Location: Brighton, UK Status: Offline Points: 955 |
Posted: 04 February 2009 at 6:50pm | |||
Jolly nice rack sir! Am a little suprised to see those tasty Labs controlled by budget Behringer gear (not that there's necessarily anything wrong with that), I'm wondering if you are satisfied with the current arrangement or do you have any plans to upgrade them and what to? |
.:ELEMENT 5 SYSTEMS:.
numtie
Young Croc Joined: 06 November 2008 Location: wales Status: Offline Points: 585 |
Posted: 04 February 2009 at 10:48pm | |||
Another picture of a speaker looking very dark cleaned and sortid. insadently anyone who has pics of speakers that are at a venue and you just wish you mange to get a better shot i.e to dark or the color is wrong pm me and ill sort it out :) |
Disco Hire Wales
