  New Posts New Posts RSS Feed - Photoshopped mungos hifi rig?
Electrikal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Electrikal Quote  Post ReplyReply Direct Link To This Post Topic: Photoshopped mungos hifi rig?
    Posted: 23 June 2011 at 2:35pm
lol?
Edited by Electrikal - 23 June 2011 at 2:38pm
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 23 June 2011 at 2:45pm
Doesn't look photoshopped to me.
jonnyhonda View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jonnyhonda Quote  Post ReplyReply Direct Link To This Post Posted: 23 June 2011 at 3:02pm
Yes, top image seems to have used the mungos photo for, 'reference'.
FFA 10k + 6004, Em Quake, Martin H3
Friss View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Friss Quote  Post ReplyReply Direct Link To This Post Posted: 23 June 2011 at 3:17pm
There a little rivalry here since sublime borrowed some of your website Elektrical?  WinkLOL
fuzzylogic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fuzzylogic Quote  Post ReplyReply Direct Link To This Post Posted: 23 June 2011 at 3:19pm
You two need to soundclash!winner keeps all.(website inc.)
NEIGHBOURHOOD SOUNDSYSTEM
Infinitely baffled.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Electrikal Quote  Post ReplyReply Direct Link To This Post Posted: 23 June 2011 at 3:19pm
Haha, no i just noticed not saying its a bad thing and i doubt its illegal as somebody above said they used it for reference..to be honest pretty good photoshop effort! The only reason i noticed is because that's the artschools floor in both pictures and ive never seen/heard a void rig like that in the art school.
 I doubt we could win against void tbh....but we would certainly give it a bash.
Edited by Electrikal - 23 June 2011 at 3:21pm
Turbulence View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Turbulence Quote  Post ReplyReply Direct Link To This Post Posted: 23 June 2011 at 3:27pm
That's Bollox! i've heard nothing but good things about your rig!!
spongebob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote spongebob Quote  Post ReplyReply Direct Link To This Post Posted: 23 June 2011 at 3:30pm
Photoshopped or not, both rigs look beefy!
fat_brstd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fat_brstd Quote  Post ReplyReply Direct Link To This Post Posted: 23 June 2011 at 3:34pm
The reason you have never seen or heard a void rig like that is because there isnt one. Those subs have been taken from the first pre-production images of the pysco and have a completely different type of bracing to the ones which are actually available to buy.
Adrians Wall Sound System
Melbournes Rootical Warrior
Roots - Dub - Steppers
facebook page
AJordan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJordan Quote  Post ReplyReply Direct Link To This Post Posted: 23 June 2011 at 3:40pm
Yes, the top image is photoshoped. Look at the outside edge of the subs near the floor. They havnt quite cut the image close enough.
kevinmcdonough View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevinmcdonough Quote  Post ReplyReply Direct Link To This Post Posted: 23 June 2011 at 3:44pm
hey
LOL yeah its a photoshop job.   If you look at the subs, for the centre two you should be looking pretty much straight on at them, so you shouldn't see very much or any of the inner side walls.  Then as you progress out to either side you should see increasing amounts of the inner side walls of the cabs.
However on this pic they only have one cab. They have pasted 5 together to the left, and then flipped the pic over over and pasted another 5 to the right. so you see the SAME AMOUNT of inner sidewall in each one no matter where it is in the line. Compare it to the Mungo's pic where the subs at the centre are almost straight on where as the ones on the extreme edges you can see LOTS of the inner wall of the horn path and the sides of the braces.
Also the edges aren't quite correct in the void pic where they meet the floor (which is obviously just copied and pasted from your pic) they are a little too square and there's a faint dark outline that shouldn't be there.
For the kick cab the shadows are all wrong. Each one has the exact same shadowing, where the left angled part has caught the light more than the right, and the 'V' shape of shadow should change angle depending again on position in the array, it wouldn't be the same in them all as is shown.   They also all have the same little lines on the bottom left and top right corner which are the little elastic straps from the padded covers. Very possible that they would all still have their covers on, but unlikely that the little straps would all be sitting in exactly the same position.
Also, if the Flash from the camera was up high enough to cause that V shape shadowing in the kick cab, then it should also have cause some sort of similar shadowing on the mouth of the horns.
It's defo one pick of a sub, one pic of a kick cab and one, maybe 2, pics of a top cab that have been photoshopped together and then put onto the mungo's background with the floor etc.
And FINALLY, to top it all off those are Stasys 5's and either Stasys 3's or Primes.  In either case everyone knows the tops meet the subs fine and there is no need what so ever for a stasys 8 to do kick in the middle!!   So just purely on that its set up all wrong!!!  LOL
k
Edited by kevinmcdonough - 23 June 2011 at 3:48pm
tmg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tmg Quote  Post ReplyReply Direct Link To This Post Posted: 23 June 2011 at 3:45pm
must be. looking closely at the floorboards they're exactly the same. unless the posittioned the rig and took the photo from the exact same spot.
