  New Posts New Posts RSS Feed - B&C Tbx100 vs. Tbw100 in supers
_Natty_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _Natty_ Quote  Post ReplyReply Direct Link To This Post Topic: B&C Tbx100 vs. Tbw100 in supers
    Posted: 10 May 2012 at 11:07am
i don't know if my blonde could be happy about that ;)
TONY.A.S.S. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TONY.A.S.S. Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2012 at 12:55am
My Mistake, you are completely right. If I was blonde, that's the moment i would have been having.
Plans? whad'ya mean plans! I thought you said you was a designer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote _Natty_ Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 11:36am
tony, sorry but i think that the powersoft unit it's to buy for the Ipal system.....and also for the oem costumers same things.... it's about the  http://www.bcspeakers.com/product.php?id=373
but maybe you know the thingh better than anyone here...
Post Options Post Options   Thanks (0) Thanks(0)   Quote TONY.A.S.S. Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 9:03am
Just as a matter of interest, especially to our UK users. The new 18 from B and C will not be sold in the UK at this time. The info states that it's for OEM customers only and looks like you would have to buy the Powersoft unit to go with it. However, I have it from the main man that it won't happen here, but I guess nothing is written in stone so who knows, maybe in the future.
RealitySound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 2:22am
Zahir, I will find out the price of the voids (shipped) by the end of the week. I also stumbled on a source for PD drivers in Jersey. Expensive as sh1t though. They went from approx $500 usd (in the uk) to about 7-800$ in Jersey. I think I can pay someone to row some voids across the pond for less than that. I'll keep u posted.
We learn something every day, and lots of times it’s that what we learned the day before was wrong.
hmaudio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hmaudio Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 12:03am
We had some mini's loaded with tbx46, and they sound warm,but dint half shift some air for what they are.
JobSeekers SoundSystem!
We all start from the bottom, very few, in comparison, make it to the top.
Prince Zahir View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Prince Zahir Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2012 at 6:46pm
Ok thanks....honestly if i could go v18-1000s i would yet no supplier i know in uk deliver to usa. So for now im sticking with tbx until i find a uk source with voids. Thanks again
levyte357 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2012 at 6:42pm
Originally posted by Prince Zahir Prince Zahir wrote:
Levyte i did read that thread a few days ago after i saw b&c came with the tbw100, yet i was asking about a comparison between tbx & tbw in supers specifically.
My previous comments  suggest the 18tbw100 wouldn't be all that special in scoops. And cringe to think what the price would be.
For small chamber scoops, try to locate drivers which have Qes/Qts/Vas/BL/Xmax similiar to PD1850, V18-1000, Fane 18XB, PD186, B&C 18TBX100.
For medium/larger chamber,  look for drivers similar to PD1851, Void V18-1200, Fane 1000, Fane 1500.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Prince Zahir Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2012 at 6:24pm
Levyte i did read that thread a few days ago after i saw b&c came with the tbw100, yet i was asking about a comparison between tbx & tbw in supers specifically. Ive read almost every scoop topic for the past 2 years as they are written. Thanks for responding and letting us in on some of the knowledge u possess.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2012 at 6:06pm
There is more to which driver is good in scoops than just power handling.
Is sometimes good to check forum threads, than to post questions, that were answered previously.
http://forum.speakerplans.com/scoop-compatible-drivers_topic65235_page2.html
Originally posted by UpComingSound UpComingSound wrote:
any one know about then new B&C drivers
18 TBW100 - 18" EXTREME HIGH POWER WOOFER
Here's quick way to choose decent "ferrite" scoop driver for scoop.
Ignore manufacturer's sensitivity figure, only consider reference efficiency, expressed as figure between 1.8 - 4.0.
Forget all Eminence, Paudio, Cerwin Vega, Peavey drivers
Forget all drivers where Xmax < 7mm
Forget all drivers with VC diam < 4"
Forget all drivers where ref efficiency (no) < 1.8
Forget all drivers with BL < 24 (Except PD186), or  Qes > 0.35, or Qts > 0.35, or Vas > 360, or Fs > 35hz
Separate drivers into 2x groups,
BL, qts, Vas,  similar to PD1850, or similar to Void V18-1200.
Apply the above rules to the thiele/small parms, and ignore the glossy sales drivel. Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Prince Zahir Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2012 at 5:56pm
True...i like the tbx. The tbw100s seem to be very similar but with more power handling. Only problem is that they are about 1.5in too deep to fit in my cabinets. also b&c have come out with a different tbx100 thats handles 1200watts aes whereas the old model is 1000watts aes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote _Natty_ Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2012 at 1:44pm
i've tbx...they sound very different from pd or void...but is warm and you can hear the tone of evry bline...for me great solution!
web department
