TH-18 build |
Post Reply | Page 123 10> |
citizensc
Young Croc Joined: 16 October 2015 Location: Perth,Australia Status: Offline Points: 532 |
Posted: 07 August 2019 at 10:46am |
OUBAAS
New Member Joined: 20 May 2016 Location: SOUTH AFRICA Status: Offline Points: 2 |
hi my friend, is there a possibility that you can sent me the danley th18 cutting list please, and by the way you do the justice to your build you can via email me at audeymatthys@gmail.com or WhatsApp on 0766266946
zombidj
New Member Joined: 04 September 2018 Status: Offline Points: 2 |
Hola, me gustaría preguntarle algunas cosas sobre t24n. ¿Podría darme su correo electrónico?
smitske96
Young Croc Joined: 16 February 2016 Location: The Netherlands Status: Offline Points: 1085 |
Next problem.. At the moment the horn was held in place by a pretty simple wooden construction.
Knowing that the ND950 weighs more then the 4554 I'm not sure if it wil hold up under transport etc. Does anyone have any experience with the problem? And maybe have any solutions? I have a few things in mind, but maybe there are some simpler ways.
smitske96
The XT1464 is physically to big for the box. I already have the XR1464, so doing some measurements with that one is always interesting.
Jo bg
Young Croc Joined: 08 March 2017 Status: Offline Points: 552 |
Looking forward on the measurements!
What made you choose the xr1464 over the xt1464? Shape?aluminum? |
smitske96
New toy for next week
First measurements will be done with the 18sound XR1464, after that the RCF HF950
smitske96
Update about the coax top:
It's definately not a timing problem, I measured the 15 and high driver seperately, and the problem is still there. Also using some foam to dampen the soundwaves from the 15 doesn't have allot of effect. I maybe can get the BMS 4595 pretty cheap, so I'm looking at some suitable horns. I planning on using a throatadapter with the 4595, does anyone have experience with the 2" P-audio horns? (PH-942, PH-642).
RMS65
New Member Joined: 19 April 2017 Location: SLO Status: Offline Points: 8 |
https://www.twaudio.de/?s=T24N+test
RMS65
https://www.twaudio.de/wp-content/uploads/2016/03/TW_AUDiO_T24N_Tests_Production_Partner_Reprint_T24N_EN.pdf
smitske96
As far as I know, the original T24(n) uses 18sound components.
zombidj
hello the components of the t24n are the originals that the box brings? |
