Tops for Roots reggae? |
Post Reply | Page <1 3456> |
Author | |||
knet94
Old Croc Joined: 31 March 2008 Location: NW London Status: Offline Points: 1510 |
Just thought i would add something to what basshorse said. When i first got my 4590s I still ran the bullets as well for a short time as I use DBMark 2 in 6 outs so was running 6 way for a while. I found that there was no real benefit to it and it was just using up an extra amp. The 1" section of the 4590 is a completely different beast to other 1" comps and really is optimized for 6khz to 20khz. that combined with the 2" is the sweetest to my ears. |
levyte357-
Is that 1" available as separate unit ? |
BASSHORSE
Young Croc Joined: 19 September 2007 Location: wolverhampton Status: Offline Points: 1160 |
When you say "I personally use a bss fds310 for 2" & bullets" are you saying that is the sole purpose for the BSS FDS310 in that configuration and would you have other crossovers/equipment managing other frequencies e.g. bass and mids? yes mate,.i use mostec or ligwa on bass then use which ever crossover for the high ends & mids for varible control,but you have some good pre amps ther so you will soon avit sounding sweet,.the ligwa saves a lot ov assle as its 5way,.ive run the horn & bullets from ther direct & it sounds clean,.but im always tattin about with other combo's so always changin,the bss is in use most as it in my front room set up runnin 1x2" & 1 bullet inbetween 2 active monitors ontop ov 4 scoops :) sounds good,.but wen i play out i use the dynacords for stereo 4way,i run the bass out the low into the mostec then into amps sometimes for the rumble & that way i can control the cut off on the bass & control everything off one unit,but i like the sound ov the dyncord & a parametric on low sometimes,.like i say im always tattin |
BASSHORSE
but as above the bms will take some beating,.ive got seperate horns but if i had the money i would be looking to buy the bms4590 on one horn as ive got ther 1" & 1.4"s & they sound nice,.
luton_soundman
Old Croc Joined: 03 August 2010 Location: Bedfordshire Status: Offline Points: 4539 |
Yeah the charlie ligwa pre is quite good and useful
BASSHORSE
this is how the ligwa now looks,,the above was the prototype i belive,.nice bit ov kit |
toastyghost
I think it uses a unique diaphragm assembly that isn't in any other BMS unit, but it only plays from 6KHz up in that coax anyway. Just buy the coax, those and the 4594 are insane. You'd definitely only need one per side. |
knet94
No Lev unless it's a very recent addition to their range. If you're interested in it just buy the 4590s and sell your other 2"s. |
luton_soundman
Yes it was the prototype i took home to test and a/b to see where it lacks what needs changing and how it can be better. Feedback session to contribute to the final product before it was mass produced and put on the market. |
BASSHORSE
respek to that luton
Tweeter_Box
Young Croc Joined: 23 June 2012 Location: London Status: Offline Points: 859 |
fa real, 2" wicked
Beautiful bit a kit P audio 2 is probably the most used and affordable comp out there, especially in the reggae field, youd be surprised how many sound systems out here use them, even alot of the biggest sounds in the uk use them but keep quiet bout it the bms coax is very nice sounding unit for a 2+1" but so are most other 2+1 non coax combos when xovered right |
https://www.facebook.com/PurpleAudioRecords
SatvaSounds
Registered User Joined: 17 August 2016 Location: Nottingham Status: Offline Points: 72 |
right to bring this back about comp drivers, ... \for a 2 stack soundsystem, 2 scoops 2 kicks/twin cab, 2 mids , would i need x2 2" comps aswell or just 1 and tweeters?
