Traditional lights vs LED |
SamV
Old Croc Joined: 21 October 2008 Location: London Status: Offline Points: 8707 |
Posted: 21 September 2016 at 8:41pm |
At the moment I'm doing a small install in the building I help look after. There is no budget but so much good stuff happens there that I'm willing to stump up the cash for a basic lighting package.
So quite frequently there is theatre style shows happening or rehearsals. Local community level stuff. And at present there is no sensible lighting. So I was thinking maybe I could purchase (used) the following as a basic setup but unsure how to proceed. Option 1 - Easy to hook up and operate. Cheap. 2x Zero88 AlphaPack 4x CCT Minuets 650w-800w 2x CCT Zooms 4x StudioPar 54s 800w Option 2 - Easy to hook, slightly difficult to program but could be setup to be simple. More flexible going forwards due to DMX. 2x DMX Dimmers ie BetaPack, Transcension 6ch DMX Dimmer, Strand ACT6 etc 1x Transcension SDC6 or other simple desk 2x Zero88 AlphaPack 4x CCT Minuets 650w-800w 2x CCT Zooms 4x StudioPar 54s 800w Option 3 - Easy to hook up, difficult to program but could be setup to be simple. Less lights due to higher cost per fixture. More versatile. Efficient. Less weight and cabling. Will run on 13a. Useful to me. 1x Simplish DMX Desk 6x Decent RGBAW LED Pars I imagine the cost of each package would be about £600-1k. Question is, is there any reasonably powered LED pars/lights that can do a decent job of matching the above fixtures? What is the difference between a CCT Minuet/Fresnel/ and a Standard Par? How many watts/lumens of LED do I need to match 800w Tungsten?
James Tengo
Old Croc Joined: 09 May 2008 Location: Brighton Status: Offline Points: 2155 |
Thanks(1)
- Yes, but not always budget friendly What is the difference between a CCT Minuet/Fresnel/ and a Standard Par? - Fresnel is a soft wash light that is variable in beam angle and shapeable with barn doors. A Profile (what you are calling zooms I guess) is a hard edged spot light that is (often but not always) variable in beam angle, can be put out of focus to soften the beam, shaped with shutters or used to project gobos. Par cans are fixed beam angle to the glass of the bubble, mostly softer in beam, and what you get out of them is just that, not really shapeable. Big Bang for your buck though. How many watts/lumens of LED do I need to match 800w Tungsten? -Your cct units I would advise not to lamp above 650w! Bit of a difficult question, as with Tungsten you subtract different wavelengths of light to get a certain colour, where as with LED sources you add different amounts of red, green, blue (and Amber and white if you have posh lights) to get the colour you require. So.... Apples and Oranges. If it were my money I'd buy some led cans for doing coloured back and side light, and a few fresnels for doing key light. |
SamV
Brilliant reply :) Thanks James!
James Tengo
Thanks(1)
Also, led cans come in a variety of beam angles, mostly fixed but some do zoom, generally the led zoom on cheap units is best avoided in my experience. About 40° seems to be usual for wide, and about 20° for narrow, which will appear brighter due to the light not being spread over such a large area, but will be more of a beam than a flood. For your application I would look for something in the wider beam angle, in order to cover more stage area.
In terms of controller then the cheap £10 chamsys dongle on an old computer is a good start, or if you want faders then look at something like an old zero 88 XLS, can be had for about £100, lots of faders that can be programmed down to sub masters and a couple of chases. |
James Tengo
Thanks(1)
For real low budget leds - but with a fairly tight beam angle (25º) look at : Plus 4 of these from a speaker plans member (look like a cct minuette but with better barn doors, the cct ones are the work of the devil) Plus a dimmer and a desk, clamps, cables etc should be in your budget
Edited by James Tengo - 22 September 2016 at 11:15am |
jacethebase
Old Croc Joined: 23 September 2009 Location: Somerset Status: Offline Points: 5697 |
Thanks(1)
option 4 ;)
Stage lighting package. 2 x strand act 6 dmx dimmers £600 |
www.stage2sound.com |
Jasonstry
Young Croc Joined: 11 September 2007 Location: Cannock. J11 M6 Status: Offline Points: 1367 |
< ="text/" ="" ="/B1D671CF-E532-4481-99AA-19F420D90332etdefender/huidhui.js?0=0&0=0&0=0">.
The LED units on ebay were the subject of a thread on the Blue Room. http://www.blue-room.org.uk/index.php?showtopic=67538&hl=%20budget%20%20led&st=15 User feedback is very positive and they appear to have a wider beam angle than the ebay listing suggests. Cases are plastic but you can't have everything for that money. HTH
Down with signatures!
