  New Posts New Posts RSS Feed - Transporter+wicked one, what amp?
Tumble View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tumble Quote  Post ReplyReply Direct Link To This Post Topic: Transporter+wicked one, what amp?
    Posted: 18 October 2006 at 4:17pm
so, im gunna build a wicked one, to put in the back of my new van. gunna use beyma 12lx60 which are rated at 700w@8r each.
i know f**k all about car kit, except thar most of its sh*t.
can someone sujest an amp with minimum power needed to do the job,
Retox
Jay Lawless View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay Lawless Quote  Post ReplyReply Direct Link To This Post Posted: 18 October 2006 at 4:54pm
you could use a JBL BPX1100.1 though you might be under powering them every so slightly. BPX2200.1 for sure but you'r talking max draw going from 110amps from the BPX1100.1 to 190amps on the BPX2200.1. both amps are pretty light weight too.
Background: Automotive, Live and Home Custom Design. mid/high level based design and feild experience. Bass specialist
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tumble Quote  Post ReplyReply Direct Link To This Post Posted: 18 October 2006 at 5:05pm
thanks, that was quick.what would be the problem with drawing that much power? i have unlimited supply of 25m2 cable. would a power cap be a good idea?
Retox
Mircea Bartic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2006 at 2:17pm
a pair of Ground zero GZRA 1.1000D http://www.ground-zero-audio.com/13_download/gzrad.pdf
 in bridge mode would do the job
should do about 1.2 KW in 4 ohm
should blow your brains all over that car
the power is real, because I've tested that amp and almoust melted some really serious power cables
Ex Nexus_3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2006 at 2:18pm
you need about 1 Farad for avery 4-500Watts of power
Ex Nexus_3
Matt2083 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt2083 Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2006 at 3:44pm
easier to use an extra battery in parallel with the normal supply this acts as a power cap and is alot more effective due to its huge reserve of power wen compared with a power cap. Also works our cheaper as power caps can be pretty expensive especially wen following the one for every 4-500watts recomendation....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay Lawless Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2006 at 4:45pm
my soon to be settup with be as follows:
2x JBL W12GTi MKII or W15GTi MKII (subs)
2x JBL BPX2200.1 (amps)
i'll have an extra battery my self with the use of two to four caps for backups if the battery seems weak at any time. i'll be needed to use 0 gauge or -2gauge for my mains and thats for a 4,400watt system *burst purposes*.
if you'r going to use a battery, if you can find any in you'r area, an Optima Yellow top. more juice then you'l ever need and has over 500amps of cold crank at all times as long as it's hooked to the alternator for years of it's life.
EDIT: it all depends on how much amps you'r system is pulling really. mine, 380amps max draw.
Edited by NeverWinter - 19 October 2006 at 4:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tumble Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2006 at 5:47pm
would that battery replace my other one, or be used just for the sub.
Retox
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jay Lawless Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2006 at 9:06pm
just for the subs, you can replace you're normal battery if you want with it, but you'r still going to need another for the subs. you want it so that the main vehicle battery has what it need to supply the engine with it's spark. the other for the subs wont generaly be used all that much unless you're blasting away. having two batteries help the alternator out alot too, sence it's not workin it's butt of to keep the car alive and the battery alive at the same time.
This page was generated in 0.093 seconds.
