Tsm4 turbosound 18" |
kunak23
Registered User Joined: 22 April 2009 Location: Nothern Spain Status: Offline Points: 135 |
Posted: 19 April 2017 at 6:46am |
Hello, i need 18" a replacement for a tirbosound Tsm4 . I know much has been said about this issue but i just dont know where to find or which replacement in 300 watt could find.
Can anyone suggest any sollution? |
Robbo
Old Croc Joined: 05 December 2005 Location: Shropshire Status: Offline Points: 4221 |
Is t an early TMS4 with Fane drivers or the later model with PD inside as I have some TMS4 drivers buried in storage at present.
sgarfa
Registered User Joined: 10 December 2013 Status: Offline Points: 101 |
I enter into the discussion ... in the unlucky case you burn a woofer, I thought about changing all the woofer of my tms4, so as to not alter the design's of the spaker, i should use a very fast woofer with a light mms (ca.155gr) , nowdays aren't a lot of 18" 3 iches woofers...but
Someone knows or, I've tried other wooerfs? for me this is a good rcf l18s801 |
kunak23
Hello, i got some suggestions like pd184 or pd184c1, but this one is 700w speaker...
cravings
watts are not important really when choosing a replacement. find the T/S parameters of the pd182, and look to see what's as close as you can get to that.
also, i don't know the tms4, but in the TSE 18" sections, there's very little space for the driver, so be careful of that too. |
sgarfa
