Turbosound plan |
Post Reply | Page 12> |
AcidAda
Registered User Joined: 03 December 2006 Status: Offline Points: 2 |
Posted: 03 December 2006 at 1:53pm |
hi all,
I am looking for plans of speakers you can see on the picture below. Above all the horn, but the mid top would be good also.:) I think it is older model of TURBOSOUND speakers (I didn't find it at turbosound web site). I have gone through the forum, but without effect. Is in horn 18" speaker inside. Is it the same construction like ES-18BPH? I would like make by twos pieces horns per side. Ada |
Nigey-C
Registered User Joined: 06 February 2006 Location: Grimsby... FISH Status: Offline Points: 1342 |
bass cabs look alot like the ASS BS600
can be found @ http://www.assspeakers.com you can also find some tops that look a lot like the ones in your pic. |
specialjustin
Young Croc Joined: 18 November 2006 Status: Offline Points: 555 |
If there are bs600's, then the internal costruction is not like the ES-18BPH
AcidAda
Thanks for quick reply guys.
It realy looks like BS600 and how in this topic man writes, THEY DESIGNED AND BUILT GEAR 4 TURBOSOUND. In this case, have anybody plan for BS600? I think that in ES-18BPH is the driver turned conversely, have I right? |
gingerbiscuit69
Registered User Joined: 23 September 2005 Location: United Kingdom Status: Offline Points: 2540 |
theres better designs out there!.... they are well old!
Richard Hart
Young Croc Joined: 08 November 2005 Location: Leeds Status: Offline Points: 637 |
Has technology moved on that much?
gingerbiscuit69
horn technology hasnt really, but driver have, so inding a design tuned for a modern driver with higher power rating and efficiency will make more bang for your watt!
tv00
Old Croc Joined: 10 August 2009 Location: Denmark Status: Offline Points: 1886 |
This is a funny topic!
To me it just looks like the tse system, 8 pcs tse-111 & 8 pcs tse-118 Just googling around for old turbo threads... |
shagnasty
Spot on, that's exactly what it is, and there a VERY few designs that touch a TSE-x18 to this day as the 18" plays upto 250Hz, clean....
tv00
Funky drive unit, small VC & MMS, springy, poke it and it jumps, tap it & it says yeah!
Not like most heavy 18" cones. |
cravings
not easy to find the old drivers any more though sadly.
tv00
Equals are still made & sold:
Funktion one has something equal, f118 / 218 claims response +-3dB up to 280 hz: http://www.funktion-one.com/products/f118-mk2/ But operating band is set up to 200hz Tsw-718 claims response +-4dB to 250 hz |
