Turbosound TSE 211/215 Good? And Value? |
Post Reply | Page 123> |
Aztor
Registered User Joined: 22 September 2010 Location: Norway Status: Offline Points: 381 |
Posted: 11 May 2012 at 9:18pm |
Ok, So I'm having a "turbo rush" this month. I have just bought 4x TMS4 & 4x THL-811 I have seen some other turbo for sale. Is the TSE 211 and 215 good? I did only find one good thread regarding the 211. And a couple of threads regarding copys of the 215's. Whats the value of the 211 & 215? And how do they sound? Is 400£ per box cheap? (Same price for the subs and tops). The shape of the boxes and drivers are good. There is 8x 211 8x215 for sale. I know its an old box, but its Turbo. And would it be possible to mix with the TMS4 or THL811? |
will_i_am
Registered User Joined: 16 March 2008 Location: Manchester Status: Offline Points: 566 |
the 211's seem fairly rare, basically two tse111's stuck together, which is the 10'' and 1'' section of the tms4, they would mix but i wouldnt be confident i could array them properly and avoid comb filter city.. i cant picture how it would all fit together with what you have now! what do you have to go below the 811's and tms4 at the moment? £400 a box is about the going rate depending on condition i would say.. i think for that kind of money there is better low end to be had.. do you want to build a fully vintage turbo system?
will_i_am
are these 211's the 2*10'' stacked horizontally or vertically? ive seen both up for sale in times gone by
Aztor
I'm pretty sure its the vertically stackable 211s. How do they compare against the TMS-4 on mid-top?
add on. Just saw they are selling 24x Crown MA 5000VZ + 16x MA3600. and a lot more. Edited by Aztor - 12 May 2012 at 3:44pm |
shagnasty
The TSE-211 V2 was half a TMS-3 with a pair of 1" on a V2 device, really impressive SPL...
The HF Guide is ontop of the 2 10"s so they would sit on a TMS-4 and array well...
will_i_am
i bow to your old croc wisdom! maybe the horizontal ones ive seen were frakenstien boxes someone had made or custom?
shagnasty
shagnasty
They are listed (V2 loaded) Here :-
4D
Edited by 4D - 12 May 2012 at 8:59pm |
shagnasty
The Mid-device and and 1" wave guide form a square so you can whip then out and put them back in @ 90 degrees so you can hang them on their sides for installs with low ceilings or that require more width...
Aztor
shagnasty: Looks like you know a lot regarding Turbo cabs! Thanks.
I did see the PDF before I started the thread. If they basically are a TMS-3, minus bass, then it's great. I found an excel file containing the replacement drivers for turbosound speakers, and looks like the same drivers are used in the tse-211 & TMS-4, confirming what shagnasty said. |
4D
I have never seen one like that, surely the surround is cut out for the two mouldings from one piece of ply. ?? |
