Turbosound TSE 211/215 Good? And Value? |
Post Reply | Page <123> |
shagnasty
I have to say I've never done but a guy that worked at Turbo (Bogieman if anyone knew him) said it could be done and I've seen tms4s go on eBay in horizontal mode and get re-sold acouple of weeks later in normal mode so i believe it can be done....
4D
Rotatable possibly he was mistaken, I owned 32 of the things for some 12 years and methinks its just not, possible, starting with the 2" difference between height & width. The partition between the 10" and the 1". The the cross member that the Beyma pokes through, really it would require some serious modification of the mouldings and some really drastic moves with the woodwork. I still have half a dozen up the back of the shed if I get time I will whip a back panel off and take a pic'
Aztor
Registered User Joined: 22 September 2010 Location: Norway Status: Offline Points: 381 |
What shops & persons are selling spares for the Turbosound speakers? TMS-4, 811 & TSE-211.
shagnasty
Now I need to find a sideways TMS4 to take the back off!!!!!!
shagnasty
Thanks(1)
Mark @ Bonza sound (again UK) knows a lot about Turbo Boxes and was talking about a Dutch Company with a load, may be worth calling him and getting there details as they would probably have contacts with the mainland European Turbo community...
All else fails I know the Band Iron Maiden still have a load of TMS-3s (all V1 so no 1" drivers) but, to be honest the 10" is the critical bit and and the 1" are beyma/EV OEM anyways.
If it helps a company I work for will be in Stravanger for Offshore Northern Seas 2012 and I am sure i could get a few drivers put onto the truck if you could get them to me in the UK....
Aztor
Thanks! I have brought two, so will be good to get 10x turbo tops.
Aztor
Ok, I'm thinking about some subs. What is recommended under the TSE-211?
- tse215 - TSW-124* - TSW118** - Martin 215 MK2 - Funktion-One 218 - Thl-828 - TSE218 *I have read that it is "slow" ** The bottom end of TMS-4? |
shagnasty
A TSE 215will give you a TMS3 when coupled with the 211, but no sub, but may be an option.
A TSW-124 is the size of a TMS-3 on it back, weighs a tonne, won't play over 90Hz (you need to hit 250Hz to meet your 10") and is pretty musch known for killing crew and slipping magnets...
A TSW 118 won't run up to 250, won't produce much sub but won't kill you.
The Martin is the wrong colour and shape, and will struggle to 250 from memory, great box but, no....
FK-218 can't hit 250 either, great box but not for this...
No idea about the THL series, the Hi-light was a bit 3rd world IMHO
A 218 will give you the same output as 2 x TMS4s, if you can find some I would use thes sat on TSW-721s or TSW-718/FK-218s....
Aztor
The specs for the TSE-211 states 150hz as low xover:
http://www.sonoeseo.com/files/docs/Turbosound_TMS-3.pdf Is this wrong? |
shagnasty
Every box I have run with a 10" on a Turbo Mid-Device has had a 250 cut point, I am not saying it won't get to 150, but I susptect the sound won't be pleasant, the efficiency of the whole job will go south and the chances of shredding it you increase expotentially...
I have to assume this is a mis-print, the fact the box has 2x10" won't alter the low end extension as they are sealed in the "Turbo fruit bowls" at the back....
Unless you can find a pallet of spare drivers, I'd go LR24@250!!!
shagnasty
In fact even that link agrees :-
Aztor
Hmm. I think I will go 2-way sub then. 2x15" tubostyle kickbins. Something like 2x HD's. With something else beneath. Would USB or ES18-bph work?
