UK plug on new proline |
rosssss224
Registered User Joined: 25 July 2012 Status: Offline Points: 447 |
Posted: 18 January 2017 at 1:24pm |
Can anyone verify the following making a proline UK ready? 2. Attach one of these 3. Plug above into one of these? |
Earplug
Your links don´t seem to be working, but why not just stick on a standard UK 13A plug?
rosssss224
been told the 6mm wire is a bugger to fit to a standard 13a plug
rosssss224
http://erpimgs.idealhere.com/ImageFormal/a2/d2/af/a2d2afac-4089-46f7-9046-34e9c3d6d449/heads/E8C97FC2-3A51-4DC9-B681-A3A6267350D4.jpg
then.. Edited by rosssss224 - 18 January 2017 at 1:51pm |
Earplug
The Proline 3000? Are you sure it comes with 6mm cable? That doesn´t sound right.
Dub Specialist Sound
dont think it that size tbh, crest 9001 now thats a serious cable
just put a ceeform on, with a tail lead made up for 13a venue supplys
Earplug
Yes, I´ve seen some Crests/Crowns with US sized cable on them, ie double the section you´d get in Europe. Not sure if they were conversions or what, but a real PITA to wire to a 16A Schuko!
dylan-penguinmedia
Old Croc Joined: 14 April 2011 Location: Brighton Status: Offline Points: 4576 |
A 16a ceeform on the amp flex, with a 13>16a jumper made up, is the most sensible and flexible way to do it.
rosssss224
Thoman actually threw in one of these https://www.thomann.de/gb/thomann_adaptor_safety_plug_uk.htm
which solves the problem. Thanks for the responses.
levyte357-
I wouldn't use that if I were you. Like Dub Specialist said, put 16A ceeform plug on the Proline cable, sure it is only 4mm2. Then make up "tail", with 16A Ceeform socket and Sturdy 13A plug. Edited by levyte357- - 19 January 2017 at 1:12pm |
Agreed Lev too, dont use that adaptor thing imho
like lev says, get a nice Perma plug top, not a micky mouse ones from home bargins
rosssss224
just cheap and greater chance of failure? or dangerous?
Ill go down the ceeform route |
