  New Posts New Posts RSS Feed - ultimate reflex for sub
 Post Reply Post Reply Page  <1234 6>
sn95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sn95 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2014 at 10:52pm
This is the cab I was referring to earlier, made out of 1" Birch 2" baffle etc.
<a href="https://imageshack.com/i/ndar0rj" rel="nofollow">
                    <img src="https://imagizer.imageshack.us/v2/240x320q90/c/841/ar0r.jpg" /><!--0-->
               <span ="cover"></span></a>
So you are saying that puts out as much SPL as your RX18 ?
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2014 at 10:56pm
While reflex are the definite choice for many gigs/venues, 4x decent scoops will cover 400-500 people with effortless sub.
Many such venues will only have 13A plugs, and may struggle to provide power for 8x 18s to do the same job, if bass heavy material is played.
MRT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MRT Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2014 at 11:07pm
Originally posted by MRT MRT wrote:
So are you saying that if I have 4 superscoops loaded with PD 1850's and8 reflex boxes with the same driver, with right tuning I get at least the same spl with reflex compared to the scoops  but the reflex goes deeper and doesnt have a dip in the frequency response?
1850 is just horrible in a reflex box.
Yes thats what I thought, that it doesn't work like that. I guess the original question was if some of you would have opinions on the best way to produce sub bass with reflex design equivalent of spl produced by for example 4 super scoops with PD 1850's. To get the same pressure but reflex sound quality.
https://shack.com/idar0rj -
I guess this design is not available??? Could you tell a bit more, drivers, tuning freq, etc.?
What is the difference in having double 18" box instead 2 x 18" boxes? I know this has been discussed here before but didn't really find an answer, just that its not a big difference.
This is a good and practical point.
Many thanks for all your answers!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2014 at 11:35pm
Lev, if you do gigs on 13A plugs then that is a pure amateur gigs then.
I can not think of any venue here that does not have at least 3phase 32amp socket available. With 64A being a standard norm.
So if the power is not a limiting thing, then surely there are double 18s that will go lower and louder then a super scoop loaded with a PD1850. Which i think was the original question.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2014 at 11:46pm
Except Macedonia is not the UK, so what you have there is irrelevant... LOL
Have "personally" never been impressed by 1850 in Superscoop. V18 in Superscoop, or 1850 in ASS scoop, different ball game.
There are plenty of venues in UK, that hold 1k+ people, and only 13A mains plugs are available, unless people attempt to tail into "kitchen" supplies.
That's why to many here, "efficiency" is key. Wink
Edited by levyte357- - 13 May 2014 at 11:48pm
TmanG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TmanG Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2014 at 11:46pm
What kind of music do you want to play? Scoops have a unique scoopy sound (colouration) to them when they're holding long bass notes which some people like.
If you can provide the power I'd go with a good double 18 over a scoop much more versatile as you can run them higher and can get away without having kicks... Just my two cents, everyone will have their own.
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2014 at 11:50pm
IMHO, No point comparing Scoops to reflex cabs, people have personal choices and preferences. Mates like to use reflex for live gigs, and Scoops for 400+ people Reggae gigs.
Edited by levyte357- - 13 May 2014 at 11:53pm
geoSal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote geoSal Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2014 at 12:03am
"There are plenty of venues in UK, that hold 1k+ people, and only 13A mains plugs are available, unless people attempt to tail into "kitchen" supplies.''
Why???Ouch
What about lights??
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2014 at 12:19am
What lights? LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2014 at 12:29am
Why???Ouch
What about lights??
Gig last year that used 4x of my Scoops.
Stone Love playing on Mitchigan Vibes set, 6x Scoops in Total.
Still approx 2.5k people still there at 05:00hrs+.
All off 2x 13A plugs, as no 3ph or 32A available.. LOL
TONY.A.S.S. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TONY.A.S.S. Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2014 at 12:30am
There is no need for this design to be available as it's only a Reflex cab, although I suppose that if you don't have the wherewithal to tune, then it might be difficult. From memory, I believe the low end was in the high 20's at -3db, the speakers are B and C 18TBX100's, The cab was around 380L. 1w1m would have been around 100db. What you have to remember is that a cab that goes lower than a scoop will go further than you might calculate. Just think how, at a distance, you will always hear the lowest frequencies over the higher ones. It's just down to the longer wavelengths being produced.
I think from experience, that 2 speakers in a non separated box sound better. Others might disagree, but I think there is always an advantage with common damping that two speakers provide when working in the same cab. I would never do this in a mid cab due to the possibility of standing waves, which is what you don't get in a Low Frequency cab.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2014 at 12:38am
Lev, that venue has to have a main fuse box where you can connect your power cable directly to the main rods bypassing any in house fuse and use your own power distro with fuses.
But that is how pro people do the stuff. You wouldn't know any of that.
Using only two 13Amp sockets is seriously limiting the real capability of your system.
That is 26 amps total. Meaning less then 6KW for the entire system. That is about what i push in one of my subs :-)
Edited by MarjanM - 14 May 2014 at 12:40am
