until the b&c speaker limit... |
Post Reply | Page <123 |
tv00
Old Croc Joined: 10 August 2009 Location: Denmark Status: Offline Points: 1886 |
2 tier limiter
first limiter is fast but double gain (program) of the other that is slow but has half the gain (rms) Don't think it matters which comes first. The short peaks will come thru the slow limiter but will be stopped by the fast if they're too loud, long term overgain will be stopped by the rms limiter. Does the drawmer speaker protector do this? Or why do people prefer it to the avc2? |
_Natty_
Young Croc Joined: 01 April 2007 Status: Offline Points: 664 |
last friday i drive my 4 tbx with 8k.... clean but are 8k...no distortion, not sound warm like the 9001 does but whatta punch!
king david
Young Croc Joined: 17 January 2007 Location: italy Status: Offline Points: 1324 |
if you have powersoft you should be able to check how much power the drivers are getting and speaker impedance, probably your drivers in scoops go higher than 8 ohm impedance, so not getting the full watts the amp is capable to give
_Natty_
ive a cheap version...no dsp :(
