  New Posts New Posts RSS Feed - Venue 2 rebuild
Venue 2 rebuild
kong View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kong Quote  Post ReplyReply Direct Link To This Post Topic: Venue 2 rebuild
    Posted: 08 November 2011 at 12:13pm
I'm in the middle of refurbing an old soundcraft venue 2 and also an old soundcraft sm12.
I keep getting an issue of group and aux outputs coming in and out when I've got a large patch running. Tried the traditional burnishing tool wiggle which normally aids these issues to no avail and have also ensured that all loom and ribbon wiring inside is correct so just a bit stumped today. Circuitry inside the board is all metering as should be under stress tests too.
Any ideas?
Peter Moller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peter Moller Quote  Post ReplyReply Direct Link To This Post Posted: 13 November 2011 at 6:09am
Check solder joints around the channel aux send and  aux master level pots..
Also check solder joints around ribbon cable connectors
Also check if the channel and master section insert jacks need a cleaning ( use a dummy insert jack with ring and sleeve shorted to see if the channel starts passing signal )
Also.. Group assign switches - check solder joints and try some good switch cleaner ( caig deoxit works miracles on this )
Bad pots and bad solderjoints are fairly easy to discover using the handle end of a large screwdriver to give the suspect areas of the desk a good whack
keep us informed on your progress
real phone no: +45 four zero six two four four nine eight ( using obvious anti phone spam encryption )
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 13 November 2011 at 12:36pm
On the larger desks, the IDC connectors for the ribbons carry alot of cumulative current on the power conductors that can lead to internal overheating and burning of the conductors though it isnt always obvious at first glance. This is worth checking for if you have faults like that
North Staffordshire
kong View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kong Quote  Post ReplyReply Direct Link To This Post Posted: 14 November 2011 at 11:10am
Cheers for the advice,
will try this out,
I've resoldered most of the joints already but to no avail but will finish this proces off and get onto other suggestions
