  New Posts New Posts RSS Feed - very efficient bass bin
BMJ Sound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BMJ Sound Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2011 at 2:19am
You can build super scoop and load it with an 18inch 18 sound lw1400 @240 hz i have 2 and they crack the atmosphere between 20meters from the bins, got 2 crown xls 802 driving 1600 watts constant @ 8 ohms mono per driver.
Cracking the atmosphere with bass
hond View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hond Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2011 at 12:22pm
@BMJ err, i'm afraid that would be a bit too much, no?
subbass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote subbass Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2011 at 12:48pm
hd15 would be perfect
hond View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hond Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2011 at 9:38pm
how much power should I give the HD15? I think it is safe to say that I can manage to use a really big battery at least 50ah or something..
What about a 1850 bin? Has 105 efficiency and drops lower then the HD.. A little bit wider but not that much of a difference from a HD215..
jamwa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jamwa Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2011 at 9:45pm
Martinssons 15" tapped horn....very efficient and compact box. plus dosnt need a Watt heavy driver to get the output so not drawing loads os power out of the battery....
Lee In Montreal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lee In Montreal Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2011 at 12:39am
Make a copy of a JBL 4530, loaded with a 15" JBL 2226H or modify it to accept an 18" JBL 2242H. That style of scoop is very efficient. Probably 6db over a bass reflex. This is a kick bin, meaning there's nothing under 40Hz and it is optimized for 50-120Hz. The kick is impactfull and will hit you in the chest.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BMJ Sound Quote  Post ReplyReply Direct Link To This Post Posted: 21 July 2011 at 7:21am
Got 4 of those they do really hit hard on the chest with celestion ftr 4080 fd speakers real big thump
davey t View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davey t Quote  Post ReplyReply Direct Link To This Post Posted: 22 July 2011 at 9:39am
You want a double 15" bass reflex. With a decent efficient driver it will be 104db 1w/1m
We just designed and built two with your exact dimensions! Not ready to release them on the world quite yet.
domi_nic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote domi_nic Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2011 at 8:50pm
sdf
Edited by domi_nic - 01 August 2011 at 9:27pm
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2011 at 10:42pm
Why the wasted space below the horn mouth?
