  New Posts New Posts RSS Feed - Void - Line source waveguides
SvempaPrim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SvempaPrim Quote  Post ReplyReply Direct Link To This Post Topic: Void - Line source waveguides
    Posted: 21 August 2015 at 12:02pm
Hi guys! I'm kinda curios about your thoughts on the line sourceish waveguides Void has started implementing in some of their latest cabs. If you take a look at the Prime V2 and the new DJ monitor system (both are not yet on their website) you can clearly see the use of something that looks like a line source waveguide, but I'm sure as hell does not behave like one. What's the point of using waveguide likes this if a very narrow vertical dispersion is not needed? Enlighten me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 21 August 2015 at 5:14pm
Prime v2 was not a line source waveguide, just a very narrow vertical and horizontal dispersion one to facilitate that box's array intentions - it's also not on the website as it was only available for a short time before being discontinued, and is no longer available.
The new DJ monitor/low profile fill Air Series box also is designed for a narrow vertical dispersion but wide horizontal dispersion - it's designed to either only cover a DJ or be mounted close to a ceiling, to fill the gap in the product range between the Air Ten and Air Motion.
In both cases a narrow vertical dispersion is intentional - so neither are line source waveguides, they just share some properties.
Edited by toastyghost - 21 August 2015 at 5:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 21 August 2015 at 6:02pm
Why was the Prime discontinued? It was a good box.
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 21 August 2015 at 7:01pm
Simply less and less of a market for super high output, narrow dispersion heavy point source boxes now especially in the UK - even less of a market if it doesn't have a certain badge on the front.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 21 August 2015 at 7:27pm
yeah, all about lying arrays these days.
Sapro2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sapro2 Quote  Post ReplyReply Direct Link To This Post Posted: 21 August 2015 at 8:13pm
+1
Splat Soundsystem
Baby Sham pram Soundsystem
Sapro - SoundCloud
https://soundcloud.com/sapro
DJ Sapro. West country free party DJ and Producer.
