  New Posts New Posts RSS Feed - volume controls where are they!
Tony Wilkes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Wilkes Quote  Post ReplyReply Direct Link To This Post Posted: 01 June 2007 at 9:06am
Originally posted by Robbo Robbo wrote:
Switch on the Aural Exciter!!!!!!! and stand back.
Only thing that I need to switch mine on is a couple of Gins!! Oh you said aural sorry.
Thing
COWFOOT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote COWFOOT Quote  Post ReplyReply Direct Link To This Post Posted: 02 June 2007 at 3:38am
and the Crown Macros also have sensitivity selectors in rear in addition to attenuators in front.
OllieMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OllieMan Quote  Post ReplyReply Direct Link To This Post Posted: 04 June 2007 at 8:52am
Originally posted by robertnisbet robertnisbet wrote:
The Crown/Amcron amps you're probably thinking of are the MicroTech range.
HTH.
I have a Crown Macrotech, and indeed it doesn't have any pots at all.
I've used it on horns, and in the past just used my LMS to balance the midrange amp.
JD01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JD01 Quote  Post ReplyReply Direct Link To This Post Posted: 05 June 2007 at 8:58pm
I don't really need volume controls or attenuators on amps. A defined amplification is good enough any day. Pro amps are probably not used to be connected directly to a DJ mixer.....
