VU meters - essential? recommendations? |
Post Reply | Page 123> |
ednew88
Registered User Joined: 29 August 2012 Status: Offline Points: 224 |
Posted: 23 November 2014 at 10:26am |
Are VU meters essential in a traditional reggae soundsystem (i.e pre amp, 4 way)?
Doesn't seem to be too many out there for sale- do people use them and if so which models? |
ednew88
No responses? Not interesting or people don't use them?
audiomik
Old Croc Joined: 06 April 2010 Location: Bath, UK Status: Offline Points: 2962 |
Used to include VU meters or proper PPM type metering when I built some Reggae Sound bits and pieces.
Weather they were actually used I don't really know Mik |
Warning! May contain Nuts
plus springs, washers, screws, etc, etc. |
dj jammin
Young Croc Joined: 10 April 2010 Location: southampton Status: Online Points: 770 |
Hi ednew, I think the question is a bit confusing perhaps. Most reggae preamps have a set of led vu's for each music band ie: high, high mid, low mid and low. Most mixers have some kind of led vu metering. Some of the preamp builders offer an upgrade to true vu meters, but I personally feel the reason people choose these is purely to get the vintage retro look. I don't think there is a clear practical advantage over led metering, the only thing I can think of is led's can be hard to read (or tell if they are lit) under some lighting conditions.
Definitely interesting and yes people do use them..
Reverence Sound system
ednew88
cool my JTS preamp has single led's per fq band but no VU meter.
I wasn't necessarily making a distinction between traditional VU meters and LEDs- Either way there doesn't seem to be much available in terms of 19" units that are seperate VU meters or LED variants.... |
dj jammin
Now you've just given me an idea for a custom bit of kit! How about a rack unit to go above your pre. The four outputs from the pre go in, you get 4 lots of led vu meter and the outputs would balanced xlr to go straight to amps.. that would be a nice upgrade..
ednew88
spot on, this is what am after. Who makes them?
mini-mad
Make it 6 VUs and i'll stick one on the outs of my LMS... :-) |
dj jammin
you putting in an order?
ednew88
if someone can make one to do the job id be interested- at the right price :)
mini-mad
To be honest... i could prob build one myself. And even thought about it near the beginning if this year.
ednew88
what stopped you or what you using instead?
