VZ5000 problem 2 |
Post Reply | Page 123> |
vmh
Registered User Joined: 23 March 2008 Location: Portugal Status: Offline Points: 188 |
Posted: 01 November 2015 at 1:02am |
Hi.
Last night the left channel went down on my normally trusty VZ500 (again) The signal light was on as normal but the ODEP light went out, then flashed on and off constantly, accompanied by a clicking noise from the relay switching, and cracking from the speakers even with the gain off. It was like that channel was switching on and off. I had a similar problem on the same channel a while ago and was told it was probably the relay itself. Does this sound probable? |
It's not how big it is, it's what you do with it!
edboom
Registered User Joined: 13 May 2011 Location: manchester Status: Offline Points: 48 |
If your anywhere near stoke on Trent, talk to Kevin Edwards, he's on sp as kedwardsleisure or something like that. I had a similar prob with same amp, turned out to be a minor component failure. Many engineers shy away from that amp, not him tho'
vmh
I'm in Portugal but i can find him on here and send him a pm.
Cheers. |
kedwardsleisure
Old Croc Joined: 20 January 2009 Location: Staffordshire Status: Offline Points: 4938 |
Its ok, Ive just seen the thread!
Fisrt thing is to whip the cover off and see if any diagnostic lights are on or flashing. And don't connect your speakers til the amp's A1 ok again. There are lights on the main control pcb (the one on the sliding tray at the back) and a couple on the power pcb at the front. |
North Staffordshire |
vmh
Ok.
I am away for a couple of weeks now so wont be able to have a look until i get back but will let you know asap. So i need to fire it up with no load but with or without input? And see what the LEDs are doing. |
DjLeco
Young Croc Joined: 21 April 2009 Location: Bucharest Status: Offline Points: 817 |
No load, no input (volume level at minimium), turn on and tell us if instantly makes that trouble, or after couple minutes, with fan's at maximum speed.
vmh
Luckily the problem started just as i was checking on the amps so it wasn't doing it for hours before anyone noticed.
The fan is a bit lazy on that side so initially i thought maybe the fan had failed and it was overheating. I turned the gain down and disconnected the load from that side which had no effect so i switched the amp off and left it for an hour or so. When i switched it back on the problem started again straight away. Not wanting to make any problem worse i removed the amp, and that is all i know until i can test it properly in a few weeks. |
Grinner
Registered User Joined: 02 December 2005 Location: essex Status: Offline Points: 407 |
vmh
Well. i'm back in Portugal and had chance to test the VZ. Judging by the noise it was making i think this one might be a bit beyond me but here goes.
I switched it on with the gains on minimum, no input and no load. The signal lights light as normal and on the right switch off as the ODEP light comes on as normal. The left channel signal light stays on permanently and the ODEP light flicks on and off. When the ODEP light flicks on the CH1 STB1 LED inside the amp flick off and the CH1 DCLF LED flicks on. When the ODEP Light flicks off the CH1 STB1 is on and the CH1 DCLF is off. Oh and it's making a strange noise. ;-) |
kedwardsleisure
what sort of strange noise?
The stb light means the protect circuit is killing the power to that side for safety reasons. The DCLF suggests it's detected dc on the output. Check if there's any dc on the output terminals , if so it will be brief because the power will be cycling...check it with an analogue meter if possible. |
vmh
The noise is like the hum it makes when it powers up but constant and sounding strained.
I will check for DC asap. |
Jamo Supa Powa 2
Registered User Joined: 29 January 2008 Location: Birmingham U.K Status: Offline Points: 146 |
Simple but it tuff !!!!!!!!!!
