Forum Home Forum Home > Buying and Selling > Wanted
  New Posts New Posts RSS Feed - w audio sb500/sb850. D4-500. XT800
mini-mad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Topic: w audio sb500/sb850. D4-500. XT800
    Posted: 03 March 2017 at 11:37am
I have larger amps to swap with but I need one of these and/or an Matrix XT800 for a 2.1 system I'm putting together as I like my racks to match (OCD) and the little w audio sb500 I have here hasn't let me down so would like a second or the bigger sb850.
also if I can't get one of these Amps I can swap it all out and put a second xt800 in there...
as said I have a few larger amps to swap for them and or money but this is to build up a matching amp rack for a small system so I don't want to silly prices please.
Edited by mini-mad - 04 March 2017 at 6:16pm
bassdesigner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bassdesigner Quote  Post ReplyReply Direct Link To This Post Posted: 03 March 2017 at 11:57am
I have a excellent condition w audio horizon 600 1u if that's any use?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 03 March 2017 at 2:51pm
I'm trying to keep my amps all the same... I have one sb500 and one xt800... the little sb500 isn't to bad for tops on small gigs but would like to use it bridged for a single bass can and have an sb850 on tops duty.
...or like I use to have a pair of xt800 with a berry crossover set up the same way but with much more headroom (and being better amps of course).
but thanks for the offer none the less!
I have the 400 version of that in my living room on monitor duty for my decks. the fans are annoying at low levels
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 03 March 2017 at 2:59pm
double post
Edited by mini-mad - 04 March 2017 at 6:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 04 March 2017 at 6:18pm
....unless you have a matching pair...
or anyone has Thomanns 4-d500 going for cheap...
or a cheap 2U 4 channel amp that's bridgeable?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mini-mad Quote  Post ReplyReply Direct Link To This Post Posted: 15 March 2017 at 11:16am
Still on the hunt...
