W Audio Spare Parts? |
mitchiemasha
Registered User Joined: 27 August 2009 Status: Offline Points: 466 |
Posted: 20 November 2016 at 9:14pm |
I have a W Audio PSR12A in need of a new amp board and input board. Any one know of a supplier?
The tweeter and driver are fine. Another alternative would be to replace this with a crossover and turn it into passive, thoughts??? The amp board is blowing the fuses for the tweeter and playing distorted sound to the mid/low driver. The input board has had a jack (as a guess) forced in incorrectly on a mic channel, snapping the socket off, pushing back the board and damaging the rotaries. Thanks in advance. |
kedwardsleisure
Thanks(1)
the importer of W-Audio (Warrior) is Prolight Concepts
01254 704111 Probably not economic to replace the whole amp. |
North Staffordshire |
mitchiemasha
Thank you. I think making it passive might be the best option.
DMorison
Thanks(1)
Either that or see if you can snag a second hand unit cheap to use as a donor, that way at least any crossover/processing built into the active electronics is preserved so you won't risk changing the response/sound of the system by going passive.
mitchiemasha
That's always the better option to take but these don't seem to come up very often.
