  New Posts New Posts RSS Feed - Wbin JBL (SA4518 model) 18 inch
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 09 December 2009 at 9:47am
"2241 doesnt work in wbin"
It doesn't work in THIS W-bin, the back volume is way too small.
djk
giordihc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote giordihc Quote  Post ReplyReply Direct Link To This Post Posted: 09 December 2009 at 9:54am
yep sorry i meant that Smile
510 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 510 Quote  Post ReplyReply Direct Link To This Post Posted: 13 December 2009 at 4:31pm
the 2241 was built to take over from the 2240 as a direct replacement, i had quite a few jbl factory built orignals boxes that jbl sent me the replacement speakers and they were the 2241, so your saying that jbl dont know their own speakers . the 2240 was rated at 400 watts and the 2241 600 watts
Post Options Post Options   Thanks (0) Thanks(0)   Quote giordihc Quote  Post ReplyReply Direct Link To This Post Posted: 13 December 2009 at 9:53pm
jbl probably sent the 2241 because the 2240 is out of production.but they have different parameters so they cant be the same.noone,here,said"jbl dont know their own speakers"..but if you ask for 2240 and its not available anymore they have to sell something else.its normal..2240 and 2241 are both 600w continuos.
Edited by giordihc - 13 December 2009 at 10:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2009 at 1:28am
"the 2241 was built to take over from the 2240 as a direct replacement"
Only in the sense that they were both 18" in diameter.
They are very different speakers otherwise.
If you want to use it in this box, go ahead, it will still make lots of noise.
djk
510 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 510 Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2009 at 3:40am
jbl 2240 was rated at 300 watts pink noise and the 2241 600watts pink noise on the jbl spec sheet for the 2241 it says replacement with little or no box retuning need well thats from jbl i guess you know more
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2009 at 10:22am
"i guess you know more "
I certainly do!
JBL sells the same software I use.
Get some education and learn how to use the software yourself.
djk
510 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 510 Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2009 at 11:50am
i guess you did not understand what i was saying jbl sends a leaflet with the speaker and on it it says replacement with little or no box retuning need thats what i have been saying nothing else, yes the xmas is different and so on, but jbl them self say it is a replacement for the 2240  and it is a more power rated speaker as well not the same power ratings
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2009 at 12:29pm
I don't care what they say, it is not a suitable replacement for the 2240 or 2442 in this cabinet.
If you want to believe it, fine.
djk
510 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 510 Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2009 at 9:12pm
old cro i am just realizing what you are saying, i cant say that you are not right about the 2241 in the wbin i thought you were saying that the 2241 could not replace the 2240 in the other jbl boxes sorry sah dont blow a head gasket lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote giordihc Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2009 at 10:27pm
geez View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote geez Quote  Post ReplyReply Direct Link To This Post Posted: 28 December 2009 at 9:03am
I recently noticed P.Audio do a P180/2241 driver (and a P180/2242) are these supposed to be JBL equivalents? The P180/2241 has Fs=33Hz, Qts=0.3, Vas=311, which I think is pretty close to djk's recommended pars for a suitable driver
Tom
This page was generated in 0.797 seconds.
