what 6.5" midbass + 1.5" tweeter? |
Post Reply | Page 12> |
mk2_ginger_biscuit69
Posted: 09 July 2014 at 8:57pm |
so would like to upgrade the speakers in my cars front door, 6.5" midbass and 1.5" 'tweeters', keeping the original Siemens headunit etc as frankly cba to change it, plenty loud enough with stock speakers but distorts and gets harsh when playing heavier stuff, metal etc....
budgets not brilliant, and no, i don't want a sub! Any suggestions of something of acceptable quality? cheers Edited by mk2_ginger_biscuit69 - 09 July 2014 at 9:23pm |
i have a few Alesis m1 actives knocking about, 4ohm 6.5" midbass + 1.5" tweets i could bodge in... worth a punt?
ok, just taken out an Alesis midbass driver, at 4" deep with magnet assembly etc, i somehow doubt it will fit!
Edited by mk2_ginger_biscuit69 - 09 July 2014 at 10:06pm |
amlu
Young Croc Joined: 30 November 2009 Location: london Status: Offline Points: 740 |
beyma 605nd with a 100db efficiency? they are bit more of midrange but i wont be expecting anything better out of something so small...
immortal
Registered User Joined: 07 January 2013 Location: Sheffield Status: Offline Points: 460 |
If you have a look at the frequency response they are closer to 90db at 200hz rising to 100 at around 3k.
I was looking at using the 6mi90 which is the ferrite version of that driver but the 1mm xmax limits its mid bass response quite a bit. was simming excursion issues below about 300hz. Edit: looking at the 6mi90 the response is much flatter however the driver is half a kg heavier and slightly bigger, 73.5mm depth. It is also £75 cheaper to buy brand new. Edit 2: Or there is the Faital Pro 6FE200
Edited by immortal - 16 July 2014 at 4:06pm |
Cemetery Sounds
burningbush
Old Croc Joined: 25 May 2009 Location: Pictland Status: Offline Points: 5897 |
If you were to cut holes for the magnets to hang outside the door, you could try some 1850s in there. I would like to see this. Cyclist stuck to the magnet as you drive down the street.
burningbush
oh, and a couple of motorolas for tops gaffer taped to the dashboard - sorted like a boss.
immortal
Yeah, I reckon that would work but why not just mount the driver the other way around so the magnet is on your knee, it will help with heat dissipation from the magnet.
Cemetery Sounds
burningbush
mmm, and keep you warm in winter and the car might pass its MOT. I bow to your superior door knowledge.
burningbush
When are you going to learn, Ginge, not to post questions?
Somebody said that if you want an answer on the internet, don't post a question - you will get endless debates and arguments (or me). The correct way is to post the wrong answer, you'll get your correct answer in minutes. |
bitSmasher
Old Croc Joined: 23 June 2012 Location: Melbourne Status: Offline Points: 2295 |
Is the driver from an M1, a reflex box, best suited for flapping around in free air?
GEB
Old Croc Joined: 13 November 2009 Location: East Midlands Status: Offline Points: 1993 |
