  New Posts New Posts RSS Feed - what amps do i need for this speaker config?!?
micmic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote micmic Quote  Post ReplyReply Direct Link To This Post Topic: what amps do i need for this speaker config?!?
    Posted: 31 May 2016 at 12:29am
Hey, I would like to know what kind of amplifiers would i need to power the following configuration of speakers!
CASE 1:
6 x tops (3 on each ch)
LF: 2 x 12" 1000w 8 ohms
MF: 4 x 6" 800w 8 ohms
HF: 2 x 2" 200w 8 ohms
3 x dual 18" subs (1000 w 8 ohms each driver)
CASE 2:
same as case 1 but with 4 x tops (2 on each row) and 2 x dual 18" subs
I understand I need to bi-amp the system so please let me know what kind of amps i would need for both the tops and the subs in each case, I am looking for general amp specification that would match this speaker config but make and model would also be helpful.
THECANDLEMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote THECANDLEMAN Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2016 at 8:33am
We could give you advice based on numbers and say use 1.5x-2x watts per channel
but do you have a specific design of top and sub you are using
and with amps are you wanting to buy new or used ??
Motion Systems - Void Airmotion, Airten & Stasys 218 With Powersoft DSP
This page was generated in 0.359 seconds.
