  New Posts New Posts RSS Feed - What amps do i need??
sub-conscious View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sub-conscious Quote  Post ReplyReply Direct Link To This Post Topic: What amps do i need??
    Posted: 22 December 2016 at 7:17am
Hi guys im wanting some info on what amps i need to run my gear,
4x titan 48 Eminence 3015LF        450w
4x Dr300
Eminence Definimax Twelve and two NSD2005 HF                   450w + 50w +50w
4x double 18 Eminence omega pro 18a so theres 8 of those drivers       800w
Any help would be greatly appreciated
Christchuch Nz
Edited by sub-conscious - 22 December 2016 at 9:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote sub-conscious Quote  Post ReplyReply Direct Link To This Post Posted: 23 December 2016 at 12:23am
Anyone??
DJ-Versatile View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DJ-Versatile Quote  Post ReplyReply Direct Link To This Post Posted: 23 December 2016 at 2:02am
are these RMS values? What are the impedance's of each cab?
If you are the smartest person in the room, you're in the wrong room....
vertx View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vertx Quote  Post ReplyReply Direct Link To This Post Posted: 23 December 2016 at 2:52am
what's your budget?
Post Options Post Options   Thanks (0) Thanks(0)   Quote sub-conscious Quote  Post ReplyReply Direct Link To This Post Posted: 23 December 2016 at 7:01am
Yes pretty sure its rms 450w 8hms on all
and 2x 800w 8ohm drivers per box 1600w 4ohm
And budget is what will sound best :) just heard a k20 on a mates rig and i want powersoft but my bank wants SAE or something like that lol
Any word on the new fp10000q dsp??
Post Options Post Options   Thanks (0) Thanks(0)   Quote vertx Quote  Post ReplyReply Direct Link To This Post Posted: 23 December 2016 at 10:56am
I've heard a K20 on Mungos HiFi do huge damage, might be a bit overkill on a couple 1600w RMS 2x18" cabs though.
Heard some FFAs on Heartical HiFi and they also sound very good.
Could go 2 PQM8 and 2 PCM20 for the whole lot.
Plenty of options though, just depends on whats available to you in NZ.
Loads of forum topics on this, here are a few
http://forum.speakerplans.com/amplifier-suggestions_topic96529.html
http://forum.speakerplans.com/amp-for-compression-drivers_topic93329.html
http://forum.speakerplans.com/best-budget-power-amps_topic62742.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 23 December 2016 at 7:25pm
Mungo's use 800w PD drivers. four per channel. It's all about headroom.
Sinai Sound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sinai Sound Quote  Post ReplyReply Direct Link To This Post Posted: 23 December 2016 at 7:50pm
I use a K20 for 4 x 15" a side!
Headroom for days
mrdata View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrdata Quote  Post ReplyReply Direct Link To This Post Posted: 13 January 2017 at 5:19pm
If not shure of the power values.
250w RMS is the same as 400wAES
RMS x by 1.6 to get the AES value
AES devide 1.6 to get the RMS value
Edited by mrdata - 13 January 2017 at 5:21pm
