  New Posts New Posts RSS Feed - what difference do curved sections make on a horn
rogerharris View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rogerharris Quote  Post ReplyReply Direct Link To This Post Topic: what difference do curved sections make on a horn
    Posted: 22 February 2012 at 11:30am
There seems to be a lot of variation in horn designs in regards to whether curves or straight edges are used.
i.e.
Scoop bin vs Hog Scoop
HD15 vs other kicks
Funktion one/ turbo vs Xtro tops.
Any insights on this ? It seems that angled mouths shorten the path length while curved edges make the transition from the throats compression smoother.   My take on this is it is frequency  sensitive ?
i.e Looking more at the top horn designs care seems to be taken on making the design smooth at the throat, while the exit can be angled, perhaps shortening the path length there decreases back pressure from those crucial high frequencies which are shorter wavelength than these angles.  The F1 phase plug is smooth from behind if taken out, as high frequencies are most sensitive to perturbations while compressed in that slot.
In the scoops or HD15 the smoothing of the horn occurs later in the longest section, where the wavelength could interfere ?
Does that kind of summarize why angles or curves are used in specific areas ?
burningbush View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote burningbush Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2012 at 12:06pm
With subs, I should imagine that the wavelengths we are dealing with render the small differences between curved and segmented as not relevent.  At higher frequencies I think it has a great deal of effect to dispersion.  I am sure somebody more knowedgable will fill in the details...Wink
Hud 'at ye bam
Post Options Post Options   Thanks (0) Thanks(0)   Quote rogerharris Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2012 at 1:10pm
I am guessing but the the angles in the F1 horn serve to shorten the path length, so when sound exits the horn it just shoots of a couple of sides and out, where as a curved exit may be relatively slower in that regard anyway.   I was reading abridged interpretation of an old paper on compression drivers where the horn flare has to facilitate a fast wave exit as high frequencies can are prone to back propagation into the horn. I think thats what they were trying to say.
So basically it seems like this  inversion of principle.
Low frequency horn : sharp angles at throat = faster attack, smooth exit = reduces phase problems, chuffing etc..
Hi frequency horn: smooth at throat = reduced phase problems,  sharp at exit = faster wave exit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rogerharris Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2012 at 2:25pm
I dug out this interesting quote from Tony andrews PDF.  So maybe the angled flare exits do decrease the path length which paraphrasing him enhances spatial perception.  He also bashes line array system and a great deal of the PA hire industry in general.
http://303.bg/files/various/Reality_or_Soft_Focus.pdf
Proceedings of the Institute of Acoustics
Vol. 31. Pt 4. 2009
“REALITY? OR SOFT FOCUS?”
Tony Andrews Funktion One Research Limited, Dorking, Surrey, UK
High frequencies naturally have a fast rise time which correlates to transient information. Sound
arriving from a distance suffers from natural high frequency loss and therefore impaired transient
which is perceived and understood by the aural circuitry to be an indication of remoteness.
Furthermore transient information can also be compromised by smearing due to secondary arrivals
with slight delays due to their longer path lengths reflecting from ground, trees, buildings etc. This
is more likely with greater distance so it is also taken as a cue for remoteness. Whatever the
cause, compromised transient information has the perceived effect of placing the sound source at a
distance and removing its dimensional qualities which in turn impairs the feeling of involvement.
Therefore the ability of a chain of audio equipment to follow a given audio signal in all its detail is
paramount if we are to achieve reality. This ability usually falls over when we get to loudspeakers.
doober View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doober Quote  Post ReplyReply Direct Link To This Post Posted: 22 February 2012 at 8:19pm
Curved (often exponential) horns give the best loading to the driver, but aren't very useful in terms of pattern control as the higher frequencies tend to beam. A straight sided horn will give a more constant pattern, but can suffer from reflections at the mouth causing uneven frequency response (horn honk). A good compromise (for mid/high) is to use curves for the throat, straight sided middle section, and either a curve or a larger angle straight side for the mouth to improve termination.
As burningbush said, it is relative to wavelength. For bass/low mid there will be very little difference between a curve compared to a series of straight sided sections which approximate the curve.
That's my opinion of it, here is the work of someone more learn'd
http://www.xlrtechs.com/dbkeele.com/PDF/Keele%20(1975-05%20AES%20Preprint)%20-%20Whats%20So%20Sacred%20Exp%20Horns.pdf
Blahblahblah
Forum Software by Web Wiz Forums® version 10.11
