What is the name of this tweeter component? |
sonodrome
New Member Joined: 02 September 2014 Status: Offline Points: 3 |
Posted: 02 September 2014 at 9:11am |
I'm trying to find the name of this cast metal part found on an Eminence APT Tweeter:
It surrounds the phase plug and looks like some kind of waveguide. Here is an image of the piece in situ: I have lost one of these components and I'm trying to order a new one, without knowing the part name I'm not having much luck finding it. Thank you. |
bitSmasher
Old Croc Joined: 23 June 2012 Location: Melbourne Status: Offline Points: 2296 |
can you get an explosive diagram from Eminence, listing the spare part codes?
Nachural
Young Croc Joined: 15 April 2009 Location: West Midlands Status: Offline Points: 1255 |
I think if you just ask for an APT throat adaptor they
should suss what you are after. |
it's all just cardboard and magnets really
Adam_Iron_Horse
Old Croc Joined: 02 January 2010 Location: Scotland Status: Offline Points: 2043 |
Pretty syre those drivers are about 30 quid new, seems like itd probably be easier to grab a new one to me?
Kryptonik Sound Kollective
www.facebook.com/kryptoniksoundkollective |
studio45
I don't think that part is supposed to be detachable, so you're not likely to find another one available as a spare part. You're probably better off buying a new unit.
knet94
Old Croc Joined: 31 March 2008 Location: NW London Status: Offline Points: 1509 |
Hi where are you based? I've got an old blown APT80 that I'm not going to repair so your welcome to it if you want.
sonodrome
Couldn't find an exploded diagram or a decent datasheet unfortunately. Yeah I don't think that part is supposed to be removed, looks like it was epoxied on. The tweeter is a hand-me-down and it came like that. At the moment I'm running a pair of them, both without the whojammawatsit attached.
Throat adapter could be close enough, but I don't want to end up with the wrong part. Perhaps I will just email pictures and send a load of descriptive waffle directly to Eminence. I thought maybe it would be an obvious one and I was just in the dark about it - I'm just getting started building speakers, still have much to learn. Thank you for the kind offer knet94 :) I'm based in Leicester, so not local unfortunately. It does seem a shame to waste a tweeter, I might try to fabricate something, or I might just keep running it as is. Thanks for the replies everyone! Edited by sonodrome - 02 September 2014 at 5:11pm |
EdTheProfet
Registered User Joined: 01 April 2009 Location: Southampton Status: Offline Points: 87 |
APT's are a fairly cheap component and there are no spares available (other than the diaphragm which requires soldering to replace). Be warned the newer (mk2) APT's have a standard 1 3/8" external screw thread.
Since you have one with and one without do a comparison and decide if you think its worth the effort to mend it. It is a functional part but to be fair if they sound OK then carry on using them as is, the only caveat to that being that the diaphragm might not be properly loaded so power handling might be reduced slightly.
studio45
Well if it was epoxied on in the first place can you not just glue it back on? I've had the phase plug fall out of compression drivers before and just stuck it back in with a schmear of Araldite.
