What low/mid cabs ontop of Othorns? |
fractalcone
New Member Joined: 20 June 2017 Status: Offline Points: 4 |
Posted: 20 June 2017 at 5:49pm |
As we come closer to beginning construction on 12 x Othorn's, we still can't make a solid decision on which kick cabs to build. My partner seems to be leaning towards the ES15's, running either PD's or Fane Col.
While this system will be predominantly catering to the full spectrum of electronic music (specifically Psytrance and DnB) we would also like to appeal to a more varied audience, catering occasionally to festivals that also feature live performance/instruments, from styles such as Fat Freddys Drop to Beats Antique to Mad Professor. Here's some info - Othorn's are from Rici's original cnc template, running the B&C 21SW152-4 drivers - Amplifiers are Powersoft K20's (dsp and non-dsp versions) - A&H Qu-24 mixer - Tops are potentially looking like Meyer MSL4 or Turbosound TFL760h (options are limited due to isolated part of world we live in) or something similar Any more suggestions would be much appreciated..... my brain is turning to moosh Edited by fractalcone - 20 June 2017 at 5:58pm |
fractalcone
bass*en*mass
you`d need a kickfiller to cross over to "usual" 2-3way hornloaded cabs like the ones mentioned..!
sub 25ish to 80ish, kick 80ish to 160ish, tops 160ish up.. |
Keen
Young Croc Joined: 30 May 2011 Location: Brisbane, Aus Status: Offline Points: 1203 |
Thanks(1)
If you aren't too concerned about size, a 115 flh is a cost effective and efficient way to go. 4 each side gets tops above head height and lets you mono sub. The w-bin layout has a number of advantages and if designed well can really sing. + @1200 wide they're accomodating to tops
darkmatter
The question I would be asking would be "do I ever want to leave the Othorns at home and still be able to do gigs with the rest of the system?"
If yes, I'd consider dual 15" reflex for kick. If not, the choice would depend on the high x-over point to the tops i.e. straight or bandpass horns for high x-over (e.g. inna style of Martin 215mk2, Selenium 1505c1), folded if you don't need such a high x-over (e.g. ES15). Edited by darkmatter - 21 June 2017 at 3:11pm |
fractalcone
The system is catering to specific and existing clients each year, and will always remain as one (apart from the old backyard bbq ) |
moyano
Young Croc Joined: 12 May 2008 Location: Bedfordshire Status: Offline Points: 1219 |
primes....
