  New Posts New Posts RSS Feed - what to use for high tones o.t.o. 12inch midrange
ukdubwise View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ukdubwise Quote  Post ReplyReply Direct Link To This Post Topic: what to use for high tones o.t.o. 12inch midrange
    Posted: 04 June 2012 at 8:54pm
i have 4 12inch midrange drivers on a 4way mono rig and need enough treble to keep up with this set below:
-low                     4x superscoop
-low/mid 2x WBIN
-mid 2x custom closed boxes contains 12inch full range fanes.
-high
i don't to wanna burn ppl's ears with piezo's, any recommended drivers including horns for the treble/high.
prefer some budget speakers in the first place at least not high prized compressors.
Edited by ukdubwise - 04 June 2012 at 8:54pm
Andy Kos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andy Kos Quote  Post ReplyReply Direct Link To This Post Posted: 05 June 2012 at 7:59pm
Which 12 Inch Fane drivers are you using?
What amp do you plan to run the tweeters off?
Have you worked out a crossover frequency from 12 to CD yet?
www.bluearan.co.uk
Post Options Post Options   Thanks (0) Thanks(0)   Quote ukdubwise Quote  Post ReplyReply Direct Link To This Post Posted: 06 June 2012 at 7:26am
I have 2 Fane Souvereign mid range drivers.
I have a 3way JTS preamp/crossover.
bass will be splitted with an samson active crossover to seperate low/midlow
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andy Kos Quote  Post ReplyReply Direct Link To This Post Posted: 06 June 2012 at 9:37am
Fane Sovereign.... 12-300? 12-300? 12-200LT? 12-500LF????
Youve specified a 4 way system...
are you cascading the JTS and Samson crossovers for this?
www.bluearan.co.uk
Post Options Post Options   Thanks (0) Thanks(0)   Quote ukdubwise Quote  Post ReplyReply Direct Link To This Post Posted: 06 June 2012 at 10:02am
200LT
i use an samson active crossover on the bassoutput of the JTS, i have all the functions in this way just as you would use a 4way JTS, but in this way you have to control an extra unit then only your preamp.
my first plan was to build a three way rig, but i really miss the punch without kickbass, this was a much cheaper way for me to expand cause i allready had the samson unit here eating dust.
web department
