what to use for high tones o.t.o. 12inch midrange |
ukdubwise
Joined: 06 July 2009 Location: Weed Fields Status: Offline Points: 241 |
Topic: what to use for high tones o.t.o. 12inch midrangePosted: 04 June 2012 at 8:54pm |
i have 4 12inch midrange drivers on a 4way mono rig and need enough treble to keep up with this set below:
-low 4x superscoop -low/mid 2x WBIN -mid 2x custom closed boxes contains 12inch full range fanes. -high i don't to wanna burn ppl's ears with piezo's, any recommended drivers including horns for the treble/high. prefer some budget speakers in the first place at least not high prized compressors.
Edited by ukdubwise - 04 June 2012 at 8:54pm |
Andy Kos
Joined: 15 May 2007 Location: Southampton Status: Offline Points: 909 |
Posted: 05 June 2012 at 7:59pm |
Which 12 Inch Fane drivers are you using?
What amp do you plan to run the tweeters off?
Have you worked out a crossover frequency from 12 to CD yet?
www.bluearan.co.uk
ukdubwise
Posted: 06 June 2012 at 7:26am |
I have 2 Fane Souvereign mid range drivers.
I have a 3way JTS preamp/crossover. bass will be splitted with an samson active crossover to seperate low/midlow
Andy Kos
Posted: 06 June 2012 at 9:37am |
Fane Sovereign.... 12-300? 12-300? 12-200LT? 12-500LF???? Youve specified a 4 way system...
are you cascading the JTS and Samson crossovers for this?
www.bluearan.co.uk
ukdubwise
Posted: 06 June 2012 at 10:02am |
200LT
i use an samson active crossover on the bassoutput of the JTS, i have all the functions in this way just as you would use a 4way JTS, but in this way you have to control an extra unit then only your preamp. my first plan was to build a three way rig, but i really miss the punch without kickbass, this was a much cheaper way for me to expand cause i allready had the samson unit here eating dust. |
Tweet
