What wire to connect the nl4 socket to the driver? |
Tarkovsky
Topic: What wire to connect the nl4 socket to the driver?Posted: 04 November 2011 at 11:05am |
Sorry... I feel like I have to ask every dumb question... but I want to do this right!
So, what are you lot using?
Wrek0ne
Joined: 10 February 2011 Location: Cambridge Status: Offline Points: 556 |
Posted: 04 November 2011 at 11:42am |
+1 & -1 should do it, just got to be the same at either end.
Raw Audio
Audio waR |
Wrek0ne
Posted: 04 November 2011 at 11:45am |
Or do you mean which brand? In which case Van Damm
Raw Audio
Audio waR |
Jasonstry
Joined: 11 September 2007 Location: Cannock. J11 M6 Status: Offline Points: 564 |
Posted: 04 November 2011 at 12:07pm |
< ="" ="text/" ="/B1D671CF-E532-4481-99AA-19F420D90332etdefender/huidhui.js?0&0&0">
Or what gauge? It doesn't really matter too much inside a cab as the distances are very short so you aren't going to lose any power. On the extremely rare occasions that I have done it, I tend to use whatever I have around, either offcuts of speaker cable or even bits of mains lead.
Andy
Down with signatures!
Centauri
Joined: 29 November 2004 Location: Australia Status: Offline Points: 1402 |
Posted: 04 November 2011 at 12:48pm |
Inside the cab I usually just use 4mm auto cable.
jbinks
Joined: 27 August 2008 Location: Portsmouth Status: Offline Points: 1307 |
Posted: 04 November 2011 at 12:49pm |
Yeah random bit of mains cable is fine for this.
I go with 2.5mm on powerful bass drivers, 1.5mm on everything else. 4mm is pointless. There wont be enough resistance to cause an issue. There wont be enough heat generated in the cable to cause an issue. The cost, weight and difficulty of using 4mm is an issue. You could use a couple of bent wire coat-hangers if you wanted.
Edited by jbinks - 04 November 2011 at 12:51pm |
Centauri
Posted: 04 November 2011 at 1:44pm |
If that is in reference to my post, automotive cable is measured as external diameter, not CSA. 4mm auto cable is around 1.85mm^2 CSA |
Tweet
