  New Posts New Posts RSS Feed - whats best for sub dutty
UpComingSound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote UpComingSound Quote  Post ReplyReply Direct Link To This Post Topic: whats best for sub dutty
    Posted: 30 September 2015 at 2:24am
aphex big bottom 204 vs bbe 882I which one is best for sub dutty?
Conanski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Conanski Quote  Post ReplyReply Direct Link To This Post Posted: 30 September 2015 at 4:49am
You mean for proping the door open while you wheel your subs in right?
Edited by Conanski - 30 September 2015 at 4:50am
Sheggy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sheggy Quote  Post ReplyReply Direct Link To This Post Posted: 30 September 2015 at 7:23am
easiest way to blow your speakers if you ask me.
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 30 September 2015 at 7:31am
Octave dividers quadruple cone excursion.
djk
AlmostSalty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlmostSalty Quote  Post ReplyReply Direct Link To This Post Posted: 30 September 2015 at 11:45am
Watch this video:
snowflake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 30 September 2015 at 12:03pm
neither of those units are sub-harmonic synthesisers so don't increase cone excursion.
the BBE seems to just be a (poor) eq unit thought the review doesn't look at harmonic and transient response:
https://www.youtube.com/watch?v=LosL-gdHLpk
the Aphex apparently increases the sustain of bass frequencies making them sound louder.
http://www.hometheaterhifi.com/volume_11_3/aphex-204-big-bottom-7-2004.html
if I was going to try one I would go with the Aphex.
Phil
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 30 September 2015 at 2:11pm
Here is a comparison I made with three Subharmonic Synthesizers. I do not use them anymore as my cabinets are capable of playing in the teens in addition to modern music material offers more than enough sub bass within the 20 Hz - 30 Hz region.
Best Regards,
Post Options Post Options   Thanks (0) Thanks(0)   Quote UpComingSound Quote  Post ReplyReply Direct Link To This Post Posted: 30 September 2015 at 8:35pm
so which one is a good unit to invest for now? what you tink Elliot ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sheggy Quote  Post ReplyReply Direct Link To This Post Posted: 30 September 2015 at 8:58pm
Look, it depends what you want to get out of it and whether your system can handle it without incurring damage. Why don't you tell us how you plan to use it and wat kind of music you'll play. It might save you some cash on recones.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlmostSalty Quote  Post ReplyReply Direct Link To This Post Posted: 30 September 2015 at 9:19pm
Its humbug, save your money..
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 30 September 2015 at 9:39pm
the only bass enhancers worth using are those that make the bass sound better without massively increasing the amount of power delivered to the speakers or introducing frequencies too low for the speakers. the aphex looks like it might do that though I have never used one. Waves MaxBass does a different thing which might be useful to you if your speakers don't go low enough. look at either or both of those.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 30 September 2015 at 10:43pm
I bought those processors around 25 years ago when I was using Scoops. Once I got rid of my Scoops and designed my own Double Eighteens Reflex Subs which were capable of delivering bass within the teens, those processors went into retirement. I might add Bass today on pre-recorded material offers far more energy within the 30 – 10 Hz region today than in the 1990s. So if you are using a HPF higher than 20 Hz, a Subharmonic Processor is not for you.
The object of that video is for the spectator to let their ears be the deciding factor which processor would fit his/her requirement if need be.
The Aphex & Waves are not Sub harmonic Synthesisers as with the dbx and Behringer. The Aphex & Waves merely offer upper harmonic distortion giving the user the illusion that the bass is playing lower. They generally help for those who suffer in the mid bass/low midrange region. This is why, many rock enthusiasts praise the Waves & Aphex.
The Aphex is more subtle than the Waves which may be a good or bad thing pending on your requirements.
Best Regards,
Edited by Elliot Thompson - 30 September 2015 at 10:44pm
