  New Posts New Posts RSS Feed - What's more efficient
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Topic: What's more efficient
    Posted: 22 January 2012 at 12:06am
Which is the more efficient way to run amp? At 4x 8r stereo or 2x 4r bridged?
infrasound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote infrasound Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2012 at 12:24am
Which amplifier are you talking about?
A few rules of thumb with class D amps:
Higher impedances are more efficient than lower.
Idle losses make up a massive proportion of the consumed power.
System efficiency is generally highest at full power, with an 8 ohm load.
Post Options Post Options   Thanks (0) Thanks(0)   Quote infrasound Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2012 at 12:26am
Best way to do this is to buy one of these http://www.hobbyhot.com/hobbyhot-p0-high-voltage-and-precision-wattmeter-pr-2633.html
And measure the power consumption of your system at 90db pink noise and full power pink noise to find the most efficient way. You'll need an SPL meter to keep the measure the level accurately!
Edited by infrasound - 22 January 2012 at 12:26am
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2012 at 12:45am
The amp is a car amp, a Vibe Litebox 4.
Post Options Post Options   Thanks (0) Thanks(0)   Quote infrasound Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2012 at 12:49am
4*8 ohms should be more efficient.
I advise buying one of those little power-meters though. You'll learn alot about how best to run your system Thumbs Up
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2012 at 12:54am
Well for one it won't fit my 4awg cables :) Easy enough to modify?
Edited by SamV - 22 January 2012 at 12:54am
Post Options Post Options   Thanks (0) Thanks(0)   Quote infrasound Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2012 at 12:58am
slaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote slaz Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2012 at 3:19am
I have the 2-channel version of that .... working well with 2 x 8R PA-type speakers paralleled across the bridged o/p. Stable/sweet-sounding when driven quite hard .... gets a bit warm ... so need to get around to modding it with a fan.
Yours should drive 4 x 8R peakers in this way well ....
BTW this is not a class D design - calls itself class GH. More efficient than class AB though.
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2012 at 3:28am
What sorta run times you getting of which battery?
I'll be high passing around 80hz and will have a 110ah battery.
slaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote slaz Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2012 at 3:38am
Generally was getting about 5 hours from a well-used 45Ah car battery - no HPF other than the built-in subsonic - playing reggae. Would have thought you'd get at least 6-7 hours with a good 110Ah leisure battery .... should be a fair bit more if you HPF at 80.
SamV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamV Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2012 at 3:45am
Thought as much :) You're gonna love and laugh at the new system lol.
Saturnus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Saturnus Quote  Post ReplyReply Direct Link To This Post Posted: 22 January 2012 at 7:37am
That entirely depend on what impedance the amp is designed for. A typical car audio amp is more efficient with a 4 ohm load than a 8 ohm load. If we're talking class D amp that is.
For almost all other amp types like class AB and class G/H, those are generally more efficient the higher the impedance.
Edited by Saturnus - 22 January 2012 at 7:40am
Forum Software by Web Wiz Forums® version 10.11
This page was generated in 0.140 seconds.
