  New Posts New Posts RSS Feed - Which Re-Cone Glue
Which Re-Cone Glue
ashdosseposse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ashdosseposse Quote  Post ReplyReply Direct Link To This Post Topic: Which Re-Cone Glue
    Posted: 14 September 2008 at 3:03pm
Hi
can anyone tell me the glue to use to re-cone some drivers
If i had eyes and teeth i'd be a whole head! [Memoirs of an Invisible Man]
Dom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dom Quote  Post ReplyReply Direct Link To This Post Posted: 14 September 2008 at 4:12pm
It really depends on the driver.  Some drivers need more assembly than others and require different types of glue for different stages.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ashdosseposse Quote  Post ReplyReply Direct Link To This Post Posted: 14 September 2008 at 10:53pm
B & C 18" sub and some Beyma 10" mids
CHAMPION View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CHAMPION Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2008 at 8:20am
http://www.loctiteproducts.com/
Use different types of adeshives on dofferent parts on the re-cone procedure. If your not sure speak to one of the manufactures, Fane,B&C, etc for advice.
Sticks n Stones
Post Options Post Options   Thanks (0) Thanks(0)   Quote ashdosseposse Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2008 at 11:43am
Well i had one type of glue for bonding off beyma which looked like evostik plus some pva for the surround
nickyburnell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2008 at 10:15pm
What kit was it though? If the coil is already attached to the cone then you don't need that glue. Your answers are here
I use an ACTIVATED super glue for the dust caps.
Nick
Post Options Post Options   Thanks (0) Thanks(0)   Quote ashdosseposse Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2008 at 11:11pm
new cones with the coil fitted... i want glue for the surround
Pinheiro View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pinheiro Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2008 at 8:34am
hi
i done recone on more then 200 recones  from DAS, PD(turbosound),JBL,RCF and more  and the glue is always this
http://www.bartolos.pt/store/files/cola_de_contacto%5B1%5D.jpg
hope it helps yours Vitor Pinheiro
Post Options Post Options   Thanks (0) Thanks(0)   Quote CHAMPION Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2008 at 10:06am
lol Coke cola
Try getting some of this stuff, im trying to source it ....
best stuff, looks like only made in USA !
Sticks n Stones
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickyburnell Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2008 at 10:33am
Wembley LS use Tretobond
ceharden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ceharden Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2008 at 3:13pm
Myself and many other people use an impact adhesive by Evostick or Bison for gluing the spider and surround to the chassis.  Just make sure you get it in place first time!!!
Centauri View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Centauri Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2008 at 4:05pm
For spiders / surrounds / dust caps I use Bostik MultiBond , but I can't see that on the Bostik UK website - may be similar to their Evostik Serious Glue but not sure.  I wouldn't use a contact adhesive for this.
