  New Posts New Posts RSS Feed - Which Re-Cone Glue
Which Re-Cone Glue
CHAMPION View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CHAMPION Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2008 at 4:21pm
A few PD Voice coils we reworked after Carnival  5" Dia 2.5cm coil width Well Done !
Section removed to see what chemical can remove the super adhesive
Hey Presto, it has worked without damaging any material
One of the most Labour intensified chassis to work on, as the adhesive is ment for a a permanent bond! (instead of a nut&bolt use a weld) !!
This is what PD Use for Dust caps, a activator and a  cyanoacrylate adhesive
The next best thing would be to use a clear basic paper adhesive Evo-Stick 5007/2
The same  (activator and a  cyanoacrylate adhesive ) is used for Spider to voicel coil joining,
Edited by CHAMPION - 16 September 2008 at 4:28pm
Sticks n Stones
chickenfizz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chickenfizz Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2008 at 4:40pm
Araldite is what I've used for spiders and the edge of surrounds, this might not be THE RIGHT way of doing it but it's always worked for me :) I use bog standard pva for dust caps. The only time I've used different glues is when the kit actually comes with them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CHAMPION Quote  Post ReplyReply Direct Link To This Post Posted: 19 September 2008 at 8:37am
Chicken, you try and remove it if the coil blows !!! Nightmare, Labour ££ goes up
Sticks n Stones
