Why do my reflexes sound so...honky? |
Post Reply | Page 123> |
dmr
Registered User Joined: 30 July 2015 Status: Offline Points: 57 |
Posted: 16 June 2016 at 5:16pm |
I just freshly built 4 reflex subs and i'm having great trouble in getting it sounding acceptable. I'm not even sure if honky is the right word, but its really boomy/resonate-y and hard to make out anything musical.
I have tried messing around with EQ, xover points and slopes with no avail.
Specs are: 180L MDF cab (that's 180L after subtracting driver/port volumes) tuned to 43Hz Loaded with some 2nd hand 18pzb46 (one odd thing, when in the cab and I lightly flick the cone it wobbles back and fourth a few times before coming to a rest) 4 corner ports of 200mm length with an area of 9800mm^2 per port Foam damping on sides & back, not covering the entire panel but placed in the middle of each one with a ~4 inch gap around each foam sheet Driven by a bridged crown/amcron MT1201 per pair Crossed over at 97Hz Tested outdoors, elevated off a grassy floor by about a foot Simulated FR graph, for what its worth: And a semi-finished picture because who doesn't like pictures eh Any idea what could be causing it to sound like this? |
Teunos
that cab is never, never 180L.
Looking at it from the front its about 4cm wider than the 18'' woofer, minus side walls it will probably be about 45-47cm internally. Top to bottom about 50cm internally. It looks to be about 60cm deep, but lets just say its 70. Minus a few cm due to the baffle and rear panel that leaves at max +-65cm internally . Thats only 145 litres and we have not deducted the ports or speaker yet.
Best regards,
Teun. |
dmr
I just measured it, inside dimensions - 495mm wide, 570mm tall, 709mm deep
so 495*570*709 / 1000000 = 200L gross unless i'm making some mistakes somewhere...
Teunos
internal dimensions?
hmm.... Then i guess it looks bigger than i thought it would be. However, you say 4 ports of 9800 mm2, thats a triangle with sides of nearly 20*20.
Edited by Teunos - 16 June 2016 at 6:29pm |
Best regards,
Teun. |
Crashpc
Registered User Joined: 26 February 2008 Location: Czech Republic Status: Offline Points: 463 |
It would be good to measure impedance characteristics in that enclosure to see what's the tuning. 18PZB46 would be little happier in larger enclosure, but I believe it is not the only or even main problem here. Are you sure these speakers are original, and not reconed/recoiled by somebody who didn't know what he's doing?
If I count well, these ports are 14x14, not 20x20cm. That is about okay, on the low side. Edited by Crashpc - 16 June 2016 at 6:35pm |
Shortrope
What kind of Foam?....some kind of polyester wadding or Fibre glass would be better.
dmr
ceharden
180L is perfectly fine for the 18PZB46, in fact D&B used it in much smaller cabs in the C4 Sub. It's a very light cone for an 18".
What cab are you running as the mid-top above it. Subs running on their own or much louder than the mid-top can sound very odd. Outdoors, with the cab off the ground you are essentially running in free space which will reduce the bass response somewhat. Try running it in a different location, on the floor. Worthwhile checking the tuning experimentally. If the tuning is based on a simulation, without compensating for the ports being in the corners, it could be a long way out from what you expect. Been there, got the t-shirt, retuned the cab etc etc... Also, what is the bracing like in the cab? |
dmr
The mid tops are some crazy creation of 6x 6" drivers and a CTS/powerline piezo in a 75L ported cab. No idea on any of the details as they are not my work but they are the next upgrade. The snare from them will rip you in half but they really struggle to go low. Maybe I need something that can go lower to meet the subs? And what i'm hearing is a giant gap between sub and top?
Pretty minimal - the corners are braced well but the main panels aren't; I didn't get time to add it in before taking them out. How would you suggest bracing without weighting it down? One 18mm wide by 60mm tall batten down the middle of each side? Edit: Crashpc / Teunos: the ports are triangles of 140x140 (not sure of the hypotenuse) so 140*140 / 2 = 9800mm^2 each? (maths is really not my strong point!)
Edited by dmr - 16 June 2016 at 9:15pm |
Teunos
Sorry, i was having a brain fart > Sqrt(9800)*2 = +-200
This is not my day Edited by Teunos - 16 June 2016 at 10:09pm |
Best regards,
Teun. |
Teunos
Okay so please tell me i wont make another mistake here.
But i just quickly plugged your numbers into bassbox pro Are you sure that graph you posted is tuned for 43Hz? If i insert 180L, 43Hz, 4 ports of 9800 mm^2 it should be 21.0cm long, but it gives me the yellow graph. If i insert 180L, 34Hz, 4 ports of 9800 mm^2 it should be 43.0cm long, but it gives me the red graph. The red graph is very similar to yours. |
Best regards,
Teun. |
ceharden
From experience, whatever the simulation says, it'll come out at least 5Hz lower with corner ports. You get a massive amount of effective length increase due to the position.
If the mid-tops aren't meeting the subs then that definitely won't help because you'll probably end up turning the subs up more to try and compensate. Bracing-wise, corner ports do help to brace quite well. What I've done in similar cabs is a brace against the bottom, maybe 150-200mm high between two of the panels, then another one between the other two further up the cabinet. If you're intending to put handles in, bear that in mind before you choose where to put the braces. |
