Wiring 2x 4 pole speakon connectors |
NOISEYNEIGHBOURS
Registered User Joined: 25 October 2009 Location: Devon Status: Offline Points: 58 |
Posted: 30 August 2012 at 12:00pm |
Hi people of speakerplans,
I am building a 1850 loaded with a void v18 1000. I have two connectors both speakon, each one has 4 connecters. How do I wire up the connecters to the driver. Your advice will be most appreciated. Regards |
ermita
Young Croc Joined: 19 August 2010 Location: Surrey, TW10 Status: Offline Points: 1266 |
use +1 and -1
mrspeedy
Young Croc Joined: 23 July 2011 Location: Cambridge UK Status: Offline Points: 511 |
It depends what your cables are wired.
But... I would wire the positive terminal of your void to 1+ and the negative to 1- Edit: ^ Yeah that Edited by mrspeedy - 30 August 2012 at 12:07pm |
NOISEYNEIGHBOURS
thank you both, i am still trying to work out wiring the two speakons together, Im guessing 1+ to 1+, 1- to 1-, and the driver links up to the connecter that will feed the next cab (dont kno what u call it)... is this right?
mrspeedy
Yes, if you want to wire in parallel (so if you connected 2 x 8ohm subs per channel you would get 4 ohms per channel on the amp)
So if you have 2 speakon sockets on your sub, one input and one output. Wire your driver off the input 1+/1- and also solder on a short link cable that solders to the output speakon 1+/1- (so go 1+ to 1+ and 1- to 1- as you said) then you will be able to link cabs together. Edited by mrspeedy - 30 August 2012 at 12:23pm |
mrspeedy
Like that
NOISEYNEIGHBOURS
thank you! And you even answered my next question about whether to solder, i shall be printing this diagram and adding this to my plans :D
mrspeedy
No worries :D
I thought it better to solder, take the speaker cables twist the ends, tin them with a bit of solder. Tin the tab on the speakon connector and lay both cables onto it. You kind of need 3 hands but it is manageable! Good luck :) |
shagnasty
Don't use NL2 on subs, you can't get some decent cable into NL2FCs and and you can't use NL4Fs with NL2MPs so best use NL4 chassis for everything...
Wire like this :-
that way you can use 2+/- for other things by using 4 core cable!!!
shagnasty
Use at least a 50W temp controlled iron, any less than 50W you melt the connector before you get the joint upto temp!!!
