  New Posts New Posts RSS Feed - wiring speaker to speakon ,help please
sicoroots View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sicoroots Quote  Post ReplyReply Direct Link To This Post Topic: wiring speaker to speakon ,help please
    Posted: 12 January 2017 at 3:36am
Hi All
I've built a bass cab and I need to wire the driver to the speakon connector at the cab's connectors port, I am using Neutrik NL4MP 4 pole which has 4 metal plates named 1+ , 1- , 2+ , 2-
The speaker cable has 2 wires only and I'm a bit confused on which of the speakon plates I have to wire these....
big thank
cookie-dj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cookie-dj Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2017 at 4:38am
You can't polish a turd!
Post Options Post Options   Thanks (0) Thanks(0)   Quote sicoroots Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2017 at 5:21am
thank you for the diagram...I'm using one amp in bridge mode for one 600 W JBL 2226H 15" bass driver ( with same set up for a second cab ) which seems a simplified version of the diagram
based on the QSC amp manual , once bridged , I have to use use Channel 1 positive pole ( red ) to positive pole on the speaker /// Channel 2 positive pole to the negative ( black ) pole on the speaker.
this due to the bridging of the amp channels
up to here it all clear
 I 'm a bit confused when it comes to wire amps output to speakon and driver to speakon on the box.
From what I am understanding I only have to use +1 ( as the positive pole ) and +2 ( as negative pole ) on the speakon plates...
Post Options Post Options   Thanks (0) Thanks(0)   Quote sicoroots Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2017 at 5:30am
so when I look at the wiring inside the cab I have ( connection port with 2 speakon ) :
+ pole from the driver going to +1 on one speakon
- pole from the driver going to +2 on the other speakon
from here I will connect the box to the bridged amp with a speakon cable where I will always use the +2 plate as the negative pole carrier and +1 as the positive pole.
rosssss224 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rosssss224 Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2017 at 9:52am
you will need to rewire the speakon end that goes into the amp.
+1/+2 on rmx amps from memory and keep the driver end normal +1/-1
Flick the appropriate switches on the back (bridge mode etc)
Turn up channel 1 pot to full and 2 to 0 or something similar
Post Options Post Options   Thanks (0) Thanks(0)   Quote sicoroots Quote  Post ReplyReply Direct Link To This Post Posted: 12 January 2017 at 3:53pm
yes that is correct, after doing some reasearch online I found other people with same amp and set up. thank you for confirming this.
In my case I will have to use the above wiring diagram for one driver only and not two as illustrated.
The QSC amp I have ( MX1500a model ) doesn't have a speakon output port  but has regular screw nuts posts.
So I guess that I just need to get a cable that is speaker-end wired on +1/-1 poles and then use the CH1+ and CH2+ posts on the amp bridged in mono.
Amps manual also says to use only CH1 poles as input ( nothing into CH2 inputs ), turn ch2 gain all the way up and then use CH1 gain to regulate signal.
seems easier now that it was , thanks for all the replies
Forum Software by Web Wiz Forums® version 11.07
Copyright ©2001-2016 Web Wiz Ltd.
