X15 Drivers - 2014 - (£50-£100) |
Post Reply | Page 12> |
levyte357-
Posted: 22 April 2014 at 4:28pm |
X15 Drivers - 2014 - £50-100 price range, used or new,
Not interested in heavy cone sub drivers, cab will not be used full-range, sub not a priority What do people recommend, for use 100hz - 1.6khz? For testing and house parties above sub, so no recommendations for spending more "please". Edited by levyte357- - 22 April 2014 at 4:30pm |
all bass
What about those Sovereign 15-500's you have? TS parameters seem within reasonable range.
levyte357-
Need drivers with flatter response above 1.2khz in reflex, tall order for many 15" with 3"+ voice coil.
That's only reason I'm selling the pair of Fane Sov Pro 15-500s.
Actually needed drivers that are not as strong, with smaller voice coil. |
pfly
More realistic crossover point for 15" mid would be somewhere around 600-800hz range, 1khz tops.
Why? Two reasons: beaming & cone resonance/breakup. Of course if you are cheap and choose too small horn and compression driver, you'll end up with 1,6khz crossover or so... But that's just cheap and nasty. Personally I have heard, tuned and measured enough examples of this. Edited by pfly - 23 April 2014 at 12:11am |
levyte357-
If you are limited by cab size, you can't always fit huge 2" horn, & have to make do with 15"+1".
PD123ER & few other 15" drivers make decent attempt at 1khz-2khz, especially if cab not run below 80hz. |
burningbush
Old Croc Joined: 25 May 2009 Location: Pictland Status: Offline Points: 5897 |
Still beams.
burningbush
I have Gauss and gerbils that are cool upto there, but they are hard to find and for those with a light touch. I still use a 12 to bridge from the 15 to the 1", sounds nicer.
cravings
blue aran had the pd153er on special a while ago... they're supposed to be pretty good up high.
i've only tried a few 15" reflex drivers in this setup, the old p-audio sn15mb is the one i've been the happiest with. |
levyte357-
Think combination of Correct 15", 1"/1.4" and engineering skills allows decent sound, be it at reduced SPL.
Otherwise, Rog wouldn't have suggested design for 15"+1", and many manufacturers wouldn't produce this, in powered format either.
Andy Kos
What sort of power handling do you need?
levyte357-
Power handling not really the issue, 400W would suffice, if Ref efficiency 3.5%+. Really need VC no larger than 2.5"-3", approx fs=50hz, and resp upto 2khz. |
WILLZTHRILLZ
Registered User Joined: 21 April 2014 Location: up here Status: Offline Points: 201 |
Hi, what about fane sovereign 15 400? eff. 3.2% vc 2.5", fs 37hz
