X15 insulation? |
DaveZ
Joined: 28 September 2004 Location: Austria Status: Offline Points: 6 |
Topic: X15 insulation?Posted: 28 September 2004 at 10:11pm |
Hi, I want to rebuilt my mid/tops and will use the x15 plans, slightly different. Can anybody tell me what insulation material and how much I should use for the x15? Thank you Dave |
norty303
Joined: 18 August 2004 Location: Eastbourne Status: Offline Points: 7504 |
Posted: 29 September 2004 at 1:49am |
I'd say use as much wadding as possible without covering components that are likely to get hot/fire hazard. BassBin Pro modelling software gives the best results when you specify high density wadding so i went that route. Just ensure that the wadding doesn't obscure the ports - I think the generally accepted idea is that not obstruction is within 100mm of the port rear. If it works, here's a piccy of the inside of mine, the wadding is the same in the top section behind the CD too. I had to compromise as i needed a top hat on the cab but the effect it should have on the port should be minimal |
My laser stuff: http://www.facebook.com/SubsonicSystems
norty303
Posted: 29 September 2004 at 1:53am |
ok, where's the edit button.... http://myweb.tiscali.co.uk/substance/x15wad
Rog, why doesn't the site support smart tags, it'd make life loads easier (at least when I'm pissed anyway :D ) |
DaveZ
Posted: 29 September 2004 at 7:54am |
Thanks for your nice picture! Very helpful! Dave
overdrive
Joined: 13 July 2004 Location: Netherlands Status: Offline Points: 11 |
Posted: 29 September 2004 at 9:07am |
What kind of coating did you use? Trimite? And what kind of driver/horn/speaker did you use? Nice job btw! |
norty303
Posted: 29 September 2004 at 2:32pm |
Thanks for the kind words, I wish I could take the credit The cabs were built by Dom and finished by me. I think the build piccys will be on the site soon. Drivers are P-Audio SN15MB and 440 horn with a different horn to the plan spec. Paint is from Aldcroft Adhesives, textured speaker paint (can't remember the code but they only do one and a stain) Comes in at about £17 for 5kg and I can thoroughly recommend it (as Dom did to me), that finish was done with a textured roller, about 3 coats on each and it's tough as old boots |
Tweet
