X32 recording issue |
Post Reply | Page <123> |
toastyghost
Cable tester and ten minutes will tell you all you need to know.
Phil B
Old Croc Joined: 21 November 2004 Location: Melbourne Status: Offline Points: 2322 |
Just re-reading this..
Are you sending the record signals from 2 x mono aux or 1 x stereo aux? How are the original input ch's panned? Are your auxes going to master bus as well? I agree that it's probably a cable issue, just interested in the signal chain. I have had some odd recordings when using auxes not a matrix of l/r ..mainly down to how the aux is panned? Best recording we've got off the Solar rig X Air 18 was off the headfone out! No auxes left so stereo jack to 2 x XLR into a Zoom. Solo L/R and adjust level.... DON'T solo anything else for the show. Sounded amazing played back in the studio ! .p.
nuclearbass
Old Croc Joined: 06 May 2010 Location: Rotherham Status: Offline Points: 9050 |
Each of the following are sent to a separate aux out into there own channel on the zoom
Left (panned left) Right (panned right) Mic 1 (no pan) Mic 2 (no pan) Mic 3 (no pan) Crowd left (pan left) Crowd right (pan right) This is how we've always done it pretty much. Only since we moved over onto the X32 have we started having these issues. In ref to it being a cable, surely if it was a inverted cable it would effect the FOH, there's no problem with that or anything else Just the recordings, so anything pre the desk is ruled out, or is that not the case ? |
one life - have fun!
Force fusion pro audio |
RoadRunnersDust
Young Croc Joined: 03 December 2013 Location: United Kingdom Status: Offline Points: 560 |
Double check that the outputs to the zoom didn't have any phase switches pressed or delays on the outs.
As for a cable fault, check the cables that go from the Aux outs to the zoom. |
nuclearbass
Hi mate, checked for the outs to the zoom and can't see anything hung that would reverse the phase, haven't checked the cables but the cables have been used for nigh on 2 years on our other desk before we had the X32 so can't see it being them...
We did some practice recordings last night... |
toastyghost
Test the cables. If you have an issue you know nothing until you test and eliminate it.
RoadRunnersDust
Just to be clear, are you saying you have checked the phase switch is not armed or that you cannot find it on the Aux?
I have to agree with Toasty, assumption is the mother of all fuckups, test them even if you KNOW that they can't be faulty. When you say that the playback is panned hard left and right, do you mean you are sending it to a stereo aux too? As the pans on the aux do not follow the pans on the channel. If you have the input channels linked then you will have been sending both L AND R to each AUX which could be causing this |
nuclearbass
very true
Phil B
Are you taking a direct out of each channel ( post eq ) to an output independant of the aux via the in/out matrix? That way you get each channel straight off the head amp without any aux linking or pan? Also check you haven't added inadvertently different delays to different auxes...that can get quite ..interesting ! .p. |
B_Bender
Registered User Joined: 28 October 2016 Location: Surrey Status: Offline Points: 118 |
If they're phase or delay problems, Get your recording guy to fire it up in Tools and fix the problems in post!
RoadRunnersDust
What you're describing would be a Direct Out that is tapped PRE EQ.... otherwise it isn't straight off the head amp. AFAIW the X32 doesn't have any panning or linking of channels on its Direct Out tap, the only options you have are PRE or POST EQ (with or without mutes) and PRE or POST FADER (with or without mutes) Edited by RoadRunnersDust - 31 October 2016 at 3:02pm |
nuclearbass
It's direct out we need we don't need any panning or linking of channels
Not sure why he hasn't tried tht first TBH Will give it a whirl Friday |
