xta limiter settings |
_Natty_
Young Croc Joined: 01 April 2007 Status: Offline Points: 664 |
Posted: 27 April 2017 at 2:10pm |
I need some help to be sure to not make big mistake, and ive still some mess in my mind about gain, headroom, db, dbu...etc etc. the only parameter that the user can set is the thresholds gain parameter, and the docs suggest this approach:
and the table the real case:
thanks t anyone that can help me |
_Natty_
i dont know if is the raight path:
-im using k10 at 4ohm -input sens is 6,34V -output is 200V using this one http://www.sengpielaudio.com/calculator-amplification.htm should be something like in the papers: 30.457575db sound familiar? did i choose the rights inputs parameters?
Hvedstrup
Registered User Joined: 30 October 2009 Status: Offline Points: 413 |
Hi a K10 set to a standard 32db gain would give you +10 on your limiter for a rms setting.
This could be loosened up a bit for a dynamic signal since the rule is 2-2,5x the rms power of your speakers to give headroom for big dynamic peaks. Your boxes are 2400 watt RMS and a k10 is 4000 watts into 4 ohms. You should just set your limiter to ensure that it the K10 stays just below clip and you are all good.
